The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (Barnfind1951, Jerry M., DJMTruck, Dragsix, Hotrod Lincoln, 1 invisible), 260 guests, and 3 robots.
Forums50
Topics120,087
Posts961,806
Members43,554
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
U Joints
#1336016 Sun Dec 01 2019 11:57 PM
52_Ton Offline OP
Hello;
Trying to get back at this project....Working on the propeller shafts and found the U joints in need of replacement. I found a Spicer catalogue on line and it looks like #5-178x will work.
Can anyone confirm this or have a current model # that works?
This is for my 52- 9430 1 ton
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Re: U Joints
52_Ton #1336031 Mon Dec 02 2019 01:31 AM
I used that part number on my '48. I had to modify one of them for some reason that I can't now remember, grinding a little metal off for wrench access or something similar. Not a big deal or I wouldn't have done it.
Re: U Joints
52_Ton #1336032 Mon Dec 02 2019 01:52 AM
Measure old ones, search by dimension.
Ed
Re: U Joints
52_Ton #1336250 Tue Dec 03 2019 05:46 PM
Should be a Spicer # 1350. If you ask for that at O'#### or similar, they will want an application and their books don't go back that far. So pick a u-joint for a Chev 3/4 ton from however far back their books/computer go. That should be a #1350. Next size up is #1420. That won't fit. Take the dimensions with you to check.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Re: U Joints
1Ton_tommy #1336255 Tue Dec 03 2019 06:23 PM
A better solution would be to go to a driveline specialty shop and ask for a #1350 u-joint. There's one near where I live. They don't ask you year, make, model, engine, paint color, etc. They just get you what you need. They carry quality (Spicer) parts at better prices than your generic parts store.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: U Joints
klhansen #1336310 Tue Dec 03 2019 11:43 PM
52_Ton Offline OP
I used the Spicer catalogue to cross reference the 1350. I also used an indicator to measure to confirm the size.
Re: U Joints
52_Ton #1336311 Tue Dec 03 2019 11:45 PM
There's actually a place here in Pgh Pa called Driveline Service that I've delt with numerous times. I've got joints installed while I waited cheaper than I could of bought em and Installed them myself. Not to mention ,"the support small businesses thing " I like to do. I'm sure there should be something similar in your area. Hopefully
Re: U Joints
52_Ton #1336312 Tue Dec 03 2019 11:46 PM
Humm. Nice chart
Re: U Joints
52_Ton #1336314 Tue Dec 03 2019 11:51 PM
52_Ton Offline OP
I ordered 3 today and will confirm they work/ fit proper
I like doing the work when I can. The old u joints needed to be pressed out.
Re: U Joints
52_Ton #1336315 Tue Dec 03 2019 11:53 PM
You can use a ballpoint clamp/press without attachments. It works quit well really.
Page 1 of 2 1 2
Moderated by  Grigg
