The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (ESum, Old Tractor Guy, tomctomc, 1 invisible), 98 guests, and 3 robots.
Forums50
Topics119,557
Posts957,298
Members43,427
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Noisy lifter
#1336129 Mon Dec 02 2019 08:30 PM
Tiny Offline OP
'53 full pressure 235 with 22K miles. The engine has spent most of it's life just sitting. One lifter is noisy when cold and stops tapping after a few minutes. It's been just over a year and two oil changes. I'd hoped it was just a piece of debris and would eventually flush out with the clean oil but that hasn't happened yet. What's the chances this will eventually self resolve?
Re: Noisy lifter
Tiny #1336132 Mon Dec 02 2019 08:52 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Probably not. I would try Jerry’s diesel flush method. Three qts of diesel in the crankcase along with your oil and high idle for 15-20 minutes. No driving or load on the engine. Drain while hot and change the filter. Fresh oil of your choice and go for a drive. It’ll be clean enough to eat off of on the inside and everything will be thoroughly lubed.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Re: Noisy lifter
Tiny #1336133 Mon Dec 02 2019 09:04 PM
It may be air in the lifter. Pre68Dave has a fix for that on his site:
http://chev235guy.blogspot.com/search/label/Hydraulic%20Lifter%20Noise
Although the engine oil flush may cure the problem.
Professional Novice
Re: Noisy lifter
Tiny #1336134 Mon Dec 02 2019 09:11 PM
I had brand new everything on my hydraulic lifters and could never get them to stop tapping, also grooved the push rods, nothing would cure it. Finally converted back to solids and as strange as it seems, they are quieter than the hydraulics. Plus the solids tick not tap like that noisy hydraulic did.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Re: Noisy lifter
Tiny #1336137 Mon Dec 02 2019 09:46 PM
I had a brand new Ford Fiesta back in the seventies with noisy lifters. Dealer said it was natural but none of the others I listened to were that noisy. So, even under warranty, I opened the valve covers, tightened each lifter nut about a quarter turn, and quite as a sewing machine.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Re: Noisy lifter
Tiny #1336150 Mon Dec 02 2019 11:20 PM
It may need adjusting like Des says. The parts may be wore down enough that the plunger is at the end of the cyl. After it warms up the expantion takes up the slack.
Or just changing the position might do it.
George
1956 Chevy 1/2-Ton Pickup
Re: Noisy lifter
Tiny #1336159 Tue Dec 03 2019 12:21 AM
I have the same engine with similar mileage on a complete rebuild. It has one lifter which does the same thing yours does. The significant tapping goes away once the engine warms up, then runs as quiet as a mouse.
I had a discussion with pre-68 Dave about this particular issue and he said that this particular issue is not due to air trapped in the lifter and would not be fixed by making grooves in the end of the pushrod.
You either have to live with it or pull the lifter, disassemble and repair it or buy a new lifter.
Re: Noisy lifter
Tiny #1336204 Tue Dec 03 2019 05:55 AM
Chances are all repo lifters are off shore, so good luck on getting any satisfaction with that one. Just bought a delco remy dimmer switch and it literally fell apart in my hand taking it out of the box. Made in Taiwan.
1953 Chevrolet 3100
1964 GMC 1000
Re: Noisy lifter
Tiny #1336213 Tue Dec 03 2019 12:46 PM
Tiny Offline OP
It's likely an OEM lifter given the history of the vehicle.
Re: Noisy lifter
Tiny #1336449 Wed Dec 04 2019 09:12 PM
I would not use the diesel flush method to clean it when running. I did this once on an old Cadillac V8 with disasterous results. Spun a rod bearing, ruined the crank. Also be wary of replacing the lifter that has work hardened and "worn in" to that cam lobe. I would start by adjusting the lifter by the book and failing that removing the lifter, disassembling it and cleaning it in whatever your rubber gloves can stand up to. Look for a collapsed or broken spring under the check ball, a pitted check ball or seat. You can replace the internal parts of the lifter except the inner piston which is likely a lap fit to the bore. I would avoid replacing the lifter body if possible.
If you must replace the lifter body make sure that it is the proper material (chilled iron, steel, etc.) Then make sure weather the cam is ground flat or tapered. If it is tapered make sure the lifter it is ground to a crown shape and is not flat. If they are flat and the cam is tapered, they will gall one side of the lobe and/or the edge of the lifter, making short work of the cam. Many cams are ground to a 1 or possibly 2 degree offset from square with the line of the cam bearings. The object is to make the lifters rotate, reducing wear.
On a past job, I was able to grind a 1 degree crown on flat lifters that had been on another cam, which had been ground flat for reasons I no longer remember. I used a fine paper on a bench-mounted belt/disc sander with the table set to 1 degree. I checked them with a machinists square and magnifying glass under a bright light. I used cam-assembly lube and observed break-in procedures. The cam has been in the engine about 10 years and about 100,000 miles. If you are careful you can successfully do a lot of hand fitting.
I someone knows of specific years/cams that are ground flat, please weigh in here.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
Page 1 of 2 1 2
Moderated by  Woogeroo
