The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (55 SHAKER, bhap, Barnfind49, Hambone, bluesman, sweepleader), 417 guests, and 3 spiders.
Forums48
Topics117,109
Posts935,688
Members42,781
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Wanted SM 420 [Re: Tony292] #1336013 Sun Dec 01 2019 11:34 PM
Green_98 Offline
Yes, the SM420 will mount up to the torque tube. You you will need the bearing retainer and 4-speed yoke, which both are difficult to find. PM me if you want details, I just did the swap in my truck.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Re: Wanted SM 420 [Re: Tony292] #1336066 Mon Dec 02 2019 05:08 AM
KEVINSKI Offline
Was looking on e bay and a seller called French lake auto parts have what look like a sm 420 one was from a 68 Chev if it is a sm420 looked like had the back up light another was said to be from a 50;s truck but did not look correct for the torque tube you would have to contact them but the prices were right on at 150 and 175
kevinski 1954 GMC 9300 Welcome to the virtual Garage
Re: Wanted SM 420 [Re: KEVINSKI] #1336079 Mon Dec 02 2019 01:08 PM
Tony292 Offline OP
I searched Ebay for French lake auto parts and found 836 results but didn’t see any yokes or other SM 420 parts. If you happen to find it again please PM me a link. Thanks.
Re: Wanted SM 420 [Re: Tony292] #1336081 Mon Dec 02 2019 01:24 PM
Green_98 Offline
You likely will not find these parts by a simple internet search, they are rare and hard to come by, but can be found with some persistance. A junkyard with a 1/2 ton truck with 4-speed transmission is your best bet. You will also need the speedo gears as well.
There is a factory diagram in this thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=467075
Gasket set you will need:
https://www.fillingstation.com/deta...OINT_SEAL_KITSTD_TRANS_EXC_3336_STD.html
I have the part numbers for the bearing retainer and yoke at home written down in my truck log, I will have to look them up tonight.
-Patrick
1953 Chevrolet 3100
Re: Wanted SM 420 [Re: Tony292] #1336088 Mon Dec 02 2019 03:01 PM
Tony292 Offline OP
Mine is a 1.5 ton, and from what little info I can find it the yoke and u joints are different.
Re: Wanted SM 420 [Re: Tony292] #1336089 Mon Dec 02 2019 03:23 PM
sstock Offline
Well if yours is a 1.5 ton it will have the open ujoint configuration not the one of the picture you posted. Much easier to locate and you can use any open sm from 48-67.
You better get a look under your truck because you were about to buy the wrong setup. Plus, doesnt your e brake come off the side of the transmission? You will need to find a heavy duty trans that has this extra shaft on the top cover.
Steve
1953 Chevrolet 3100
261 cu inch, sm420, 3.55 rear, omaha orange, still 6 volt, RPO green glass, side carrier spare, all done
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Re: Wanted SM 420 [Re: Tony292] #1336091 Mon Dec 02 2019 03:29 PM
KEVINSKI Offline
This is what I seen
Re: Wanted SM 420 [Re: sstock] #1336094 Mon Dec 02 2019 03:52 PM
Tony292 Offline OP
I have looked under my truck many times I know it’s a torque tube and not open driveline. Mine is a 1940 1.5 ton with crashbox 4 speed and torque tube.I want to swap the crashbox over to a SM420 and am gathering the parts to do so. In order to do the swap I’ll need some parts from a 48-54 that had the SM420 set up for a torque tube. From what I know the 1.5 ton yokes and torque tubes are different than tube half ton stuff, I’m looking for 1.5 ton parts NOT half ton.
Re: Wanted SM 420 [Re: Tony292] #1336104 Mon Dec 02 2019 05:27 PM
sstock Offline
That info would of been best included in your first post. Have you thought about how you are going to hang your pedals? How are you going to account in the differences in transmission lengths with a fixed torque tube?
1953 Chevrolet 3100
1964 GMC 1000
Re: Wanted SM 420 [Re: Tony292] #1336109 Mon Dec 02 2019 06:10 PM
Tony292 Offline OP
Yes I should’ve mentioned what it’s going into. For the pedals I’m going to make a steel plate according to the pics on page 4 of this thread:
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1335326/1.html
Page 2 of 2 1 2
Moderated by  Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
