The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (reidy, 2 invisible), 185 guests, and 4 robots.
Forums50
Topics119,959
Posts960,710
Members43,525
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 4 of 5 1 2 3 4 5
Re: Replacing differential seal
Justhorsenround #1336065 Mon Dec 02 2019 04:59 AM
The crack I think is between the black lines. LINK
xfiles
glennj3 #1336070 Mon Dec 02 2019 06:23 AM
Looks more like a surface scratch to me. Can you get some dye in it to be sure?
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1336083 Mon Dec 02 2019 02:34 PM
glennj3 Offline OP
Good guess being you can't see it. It is beneath the cover but goes pretty strait to the inside. I'll need to remove the cover to get an accurate picture for you.
Are you looking at the tracing that JORB did on the picture ? Sure don't know how he did that! The crack starts at the B but does not go to B.
If I do anything more than watch it to see if it leaks, I thought I would use a dremmal tool, cut into the crack a little and fill it in with JB Weld. That stuff can do wonders!
Still having issues posting pictures from my phone and some pictures do not transfer to my computer either from the phone. I will keep working at it.
Thanks for your input.
1953 Chevy 153A, 3/4 ton, 4 stick in the floor. Not original engine, has a strait 6 chevy engine with a Ford Carburetor.
glennj3 #1336099 Mon Dec 02 2019 04:50 PM
glennj3 Offline OP
Oh Lord, I missed the instructions to pack the bearings with cup grease! I was thinking they were just bathed in differential grease! Gotta pull them off again to pack them!
glennj3 #1336100 Mon Dec 02 2019 05:15 PM
Differential grease!
I never heard of differential grease, I heard of 90 weight gear lube!
Unless you are packing wheel bearings.
glennj3 #1336103 Mon Dec 02 2019 05:23 PM
Boltergeist
Don't put cup grease anywhere, even if you can still find a source for it! The stuff has long fibers that will clog up places it shouldn't be. Maybe you could use it on some type of horsedrawn farm equipment that has actual bearing cups on it if it gets used at all! If you want to lube axle bearings, just jack up the rear end one wheel at a time after filling the center section with hypoid gear lube. The oil will run down the axle tubes and flood the bearings.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
glennj3 #1336110 Mon Dec 02 2019 06:27 PM
glennj3 Offline OP
"Grease" (the term) is sometimes used instead of heavy oil (80/90 wt). Sorry about that. I was reading the instructions on the Forum regarding what I am doing presently. It said to pack the bearings in Cup Grease after pouring axle oil on them, so that is where the term came from for me.
That is why I posted above because it seems to me that the gear lube would wash any packing grease out of the bearings and I was looking for a positive answer.
So, I do not pack the bearings with ball bearing grease, I only allow the gear lube from the differential to bathe the wheel bearings?
glennj3 #1336111 Mon Dec 02 2019 06:53 PM
Boltergeist
If you grease the axle bearings at all, simply squirt a little rear end lube on them during assembly to prevent them running dry for a few minutes until the lube from the center section makes its way down the axle tubes. If you look at the fill plug hole in the rear cover, you'll see that it's located slightly above the bottom of the axle tubes so lube can run down the tubes and keep the axle bearings wet with oil. This tendency is increased in turns once the lube reaches operating temperature. To assure the axle bearings get sufficiently lubricated after new bearings are installed, I jack up one wheel at a time and run the vehicle in place for a couple of minutes, then do the same thing with the opposite wheel before driving.
Hotrod Lincoln #1336118 Mon Dec 02 2019 07:45 PM
I jack up one wheel at a time and run the vehicle in place for a couple of minutes, then do the same thing with the opposite wheel before driving.Jerry
Warning if equipped with a limited slip or posi-traction axle,
jack up both wheels before running the vehicle. smile
Also chock front wheels.
glennj3 #1336119 Mon Dec 02 2019 07:47 PM
Boltergeist
How many stovebolts were manufactured with Positraction rear ends?
Moderated by  SWEET
