The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Flatblu4748, D B Cooper, 1951Chevy1Ton, fonz8261, chevyb, 1 invisible), 243 guests, and 3 robots.
Forums50
Topics120,001
Posts961,103
Members43,533
Most Online1,229
Jan 21st, 2020
Image Posting Policy
216 distributor location at TDC
#1335915 Sat Nov 30 2019 11:57 PM
I
Does it matter where the distributor points as long as the #1 plug wire is going to the #1 cylinder? Would the engine run if #6 was at TDC and the plug wires were set up 180 off so they #1 wire still was on the #1 cylinder?
1949 3600 216 4 speed (completely original)
Re: 216 distributor location at TDC
imstilllarry #1335927 Sun Dec 01 2019 01:39 AM
Boltergeist
The important thing is to determine which cylinder is on the compression stroke. Both #1 and #6 pistons reach TDC at the same time- - - -only one is at the top of the compression stroke, ready for the spark plug to fire, and the other cylinder is at the top of its exhaust stroke, ready for the intake stroke to begin. I like to watch the valves on the #6 cylinder- - - - -as the #6 exhaust valve closes, and the intake begins to open, #1 is on TDC compression. Point the rotor to the #1 plug wire, and set the distributor housing so the points are barely open. The engine will start every time!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
imstilllarry #1335928 Sun Dec 01 2019 01:43 AM
Yes as long as the rotor is pointed to the wire going to number one when it is at top dead center the position on the cap is irrelevant, although the wires must be in the correct firing order..
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
imstilllarry #1336296 Tue Dec 03 2019 11:05 PM
I
Ok started from scratch and know that I was TDC at #1 with both valves closed and timing mark pointed at the a hole in the flywheel. Not the BB on mine but a hole. When I rotate engine one revolution to TDC #6 now I see the BB. All I know is valves and pistons are correct for both 1 and 6 even though marks don't sound right.
Any thoughts on this, does this sound possible?
I moved my wires so rotor is at about 6 o'clock with matching plug wire is going to #1. Distributor clamps are parallel to engine. It started but was barely running. I'm going to do a static timing to see if I can get it closer tomorrow.
imstilllarry #1336302 Tue Dec 03 2019 11:15 PM
ace skiver
Both valves will be closed when either #1 cylinder or #6 cylinder is lined-up on that mark/ball.
The Stovebolt-six crankshaft moves two full revolutions for one revolution of the crankshaft.
So, yes, that mark/ball indicates 1 or 6.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Moderated by  Woogeroo
