The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (49 3100, 66flea, 95Z28A4, Bill Trotter, 3 invisible), 194 guests, and 3 robots.
Forums50
Topics120,966
Posts969,744
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Unidentified Spring
#1334835 Fri Nov 22 2019 05:52 PM
Phak1 Offline OP
AD Addict
I found this spring in the frame of my ‘52 Chevy 1/2 ton. I don’t know where it belongs or if it belongs. It’s about 1-1/2” tall. Any help would greatly be appreciated. Thanks!
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Unidentified Spring
Phak1 #1334837 Fri Nov 22 2019 06:00 PM
ace skiver
Where, and in what frame (chassis/body frame, seat frame, . . . )?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Phak1 #1334838 Fri Nov 22 2019 06:13 PM
Phak1 Offline OP
AD Addict
Drivers side just in front of the steering box. I had just removed the bypass oil filter assembly troubleshooting low oil pressure and there it was just sitting in the frame making me think it was something I did. I doubt it would have stayed in that position while I drove the truck. I thought it went to the bypass filter holding down the internal filter but it doesn’t fit around the internal pipe.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1334851 Fri Nov 22 2019 08:09 PM
The small end snaps into the bolt on the cover. it holds the cartridge down when you tighten the bolt.
George
1956 Chevy 1/2-Ton Pickup
Phak1 #1334853 Fri Nov 22 2019 08:40 PM
Phak1 Offline OP
AD Addict
Thanks, that makes sense. I’ll try that when I get home tonight.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1334897 Sat Nov 23 2019 01:28 AM
Phak1 Offline OP
AD Addict
Thanks “Wrenchbender Ret.! It fit exactly as you described. Thanks again!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Moderated by  Justhorsenround
