The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Chapman, justmike, Dragsix, 3 invisible), 185 guests, and 3 robots.
Forums50
Topics120,966
Posts969,744
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Unidentified Spring
#1334835 Fri Nov 22 2019 05:52 PM
Phak1 Offline OP
AD Addict
I found this spring in the frame of my ‘52 Chevy 1/2 ton. I don’t know where it belongs or if it belongs. It’s about 1-1/2” tall. Any help would greatly be appreciated. Thanks!
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Unidentified Spring
Phak1 #1334837 Fri Nov 22 2019 06:00 PM
ace skiver
Where, and in what frame (chassis/body frame, seat frame, . . . )?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Phak1 #1334838 Fri Nov 22 2019 06:13 PM
Phak1 Offline OP
AD Addict
Drivers side just in front of the steering box. I had just removed the bypass oil filter assembly troubleshooting low oil pressure and there it was just sitting in the frame making me think it was something I did. I doubt it would have stayed in that position while I drove the truck. I thought it went to the bypass filter holding down the internal filter but it doesn’t fit around the internal pipe.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1334851 Fri Nov 22 2019 08:09 PM
The small end snaps into the bolt on the cover. it holds the cartridge down when you tighten the bolt.
George
1956 Chevy 1/2-Ton Pickup
Phak1 #1334853 Fri Nov 22 2019 08:40 PM
Phak1 Offline OP
AD Addict
Thanks, that makes sense. I’ll try that when I get home tonight.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1334897 Sat Nov 23 2019 01:28 AM
Phak1 Offline OP
AD Addict
Thanks “Wrenchbender Ret.! It fit exactly as you described. Thanks again!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Moderated by  Justhorsenround
