The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (carbking, Barnfind49, Barney1951, Boilermaker82, 68ironhead, 1 invisible), 480 guests, and 3 spiders.
Forums48
Topics117,300
Posts937,906
Members42,893
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Will a distributor from a 216 work on a 235 engine? #1334696 Thu Nov 21 2019 11:42 PM
Geoffrey562 Offline OP
I'm in the process of upgrading my truck from a 216 to a 235. I have the original distributor from the 216 will it work with the 235? The engine is a 1951. Please go easy on me as i'm a novice and i'm learning as I go.
Thanks for the help...
1951 Chevy Pick-Up
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334697 Thu Nov 21 2019 11:54 PM
tclederman Online
Boltergeist
What year 235?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334698 Thu Nov 21 2019 11:55 PM
Sorry its a 1951 engine.
1951 Chevy Pick-Up
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334702 Fri Nov 22 2019 12:15 AM
tclederman Online
Boltergeist
A 1951 216 distributor into as 1951 235 engine?
The Master Parts Catalog shows two different 1951 carburetors - 216 vs 235.
Maybe someone knows the differences?
Tim
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334703 Fri Nov 22 2019 12:19 AM
2ManyTrucks Offline
i'm pretty sure i am using my original 216 distributor on my donor 53 235 engine, it was a fast job in the fall several years ago, so i'm hazy on the details, but seems to me the donor 235 had long lost it's distributor
i used all the working bits off the 216 when it started knocking
Generator, water pump, distributor, both manifolds with the carburetor, and the bell housing, i even took the spark plugs over to the "new" engine.
i wasn't gonna spend a dime on the switch smile
-s
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334710 Fri Nov 22 2019 12:59 AM
tclederman Online
Boltergeist
I bet that 216 and 235 distributors from the same years were/have-been interchanged (having different part numbers):
- among pre-1954 years
- among late 1955 and later years
- and, even among most 216/235/261 years?
Even though distributor gears differed significantly (as nicely described/documented by Pre '68 Dave).
Nonetheless, in 1951, there were two different part numbers.
Distributor weight springs are different.
Tim
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334770 Fri Nov 22 2019 01:10 PM
Green_98 Offline
Sounds like a perfect time to convert to electronic ignition...
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334782 Fri Nov 22 2019 01:52 PM
Pre '68 Dave Offline
I'm quite sure that the advance curve is slightly different between the two, but it will fit fine.
My Blog
Re: Will a distributor from a 216 work on a 235 engine? [Re: Geoffrey562] #1334784 Fri Nov 22 2019 01:57 PM
tclederman Online
Boltergeist
I bet you can adjust the advance curve on some of those 6v/12v electronic ignitions/distributors.
But, be sure to carry a spare original-style distributor (tuned and ready to be installed when the electronic unit fails on a long trip)? thumbs_up
Tim
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
