The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (52Carl, Lightholder's Dad, KEVINSKI, apache3600, Coltonk, 1 invisible), 385 guests, and 3 spiders.
Forums48
Topics117,320
Posts938,083
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Brake shoes for 1946 1.5 ton #1334615 Thu Nov 21 2019 02:45 PM
Libby007 Offline OP
Moderated
First time posting, hope this is the right place.
Are the brake shoes on a 1946 1.5 ton the same size as a half ton? If not does anyone know where to get them?
Thanks in advance
Re: Brake shoes for 1946 1.5 ton [Re: Libby007] #1334642 Thu Nov 21 2019 05:45 PM
Mike B Offline
No they are not the same size.
If you can't get them from NAPA or your local big truck parts store than you can have your existing shoes re-lined by your local big truck brake center (or NAPA?).
Mike B smile
Re: Brake shoes for 1946 1.5 ton [Re: Libby007] #1334723 Fri Nov 22 2019 02:01 AM
Libby007 Offline OP
Moderated
Thank you very much
Re: Brake shoes for 1946 1.5 ton [Re: Libby007] #1335113 Sun Nov 24 2019 07:10 PM
Playher Offline
Try the guys at Lincoln Clutch and Brake in Lincoln NE. They pride themselves in the old and hard to find. Had all the wheel cylinders, master cylinder, wheel bearings etc on the shelf for my 1946 2 ton.
(402) 475-1439
1946 PW Grain truck, 1966 C10 long stepside, 1975 C10 Silverado OE big block.
Re: Brake shoes for 1946 1.5 ton [Re: Libby007] #1335265 Tue Nov 26 2019 12:02 AM
4100 Fire Truck Offline
I took the trashed original rear brake shoes for my 1950 4100 to a local truck/driveline business and they sent them off to one of their shops, and 3 days $250 later I had them back, and they looked great! But, 50 miles later one of the original bearing seals leaked gear oil on one, so after cleaning it didn't work out, I'll have to send that side back out, and hope I get the same lining material. I saved the other side by replacing both seals, which I should have done in the first place. Another expensive experience.
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
