The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (brassbolt, carbking, Eureka Jim, dhjmd, fclaridge, AD8), 106 guests, and 3 robots.
Forums50
Topics119,474
Posts956,597
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Stomp starter
#1334326 Tue Nov 19 2019 01:14 PM
In perusing the 54 to 60 operator's manuals it appears that the 54 was the last model with stomp starter only, 55-59 could have had stomp or key start, and starting with 60 it was key start only. So for any that would like to reply, I would like to know what your 55-59 has.
Thank you
Re: Stomp starter
WarEagle1 #1334333 Tue Nov 19 2019 01:48 PM
ace skiver
I'll answer about foot-actuated-starters in Chevrolet trucks (not GMCs, not cars).
Stomp starters were owner-abused engine-starting equipment in trucks with a bad/weak electrical systems, bad/weak starters, or poorly tuned engines (or, an ill-tempered owner).
1954 was not the "foot-actuated-only-starters" in Chevrolet trucks. The trucks (small trucks) equipped with Hydra-Matic transmission had an electric-solenoid key-turn and push button actuated starter.
So, 1953 was the last Chevrolet truck model year with all trucks with foot-actuated starters.
The foot-actuated starter was used in some trucks up to 1959.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Stomp starter
WarEagle1 #1334335 Tue Nov 19 2019 02:08 PM
My ‘57 3200 has a dash mounted switch for ignition on, then a push button on the dash to start. It has a 350 with TH350 tranny so the starter may not be original but I like it.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Re: Stomp starter
WarEagle1 #1334338 Tue Nov 19 2019 02:18 PM
Only 6-cylinder trucks with manual trans had foot-operated starters from 55-2nd thru 59. All Hydramatic (as Tm stated) and V8 trucks had electric solenoid actuated starters.
Professional Novice
Re: Stomp starter
WarEagle1 #1334339 Tue Nov 19 2019 02:29 PM
10-4. Did ALL 55-2nd thru 59 six cylinders with manual trans. have foot-operated starters?
Re: Stomp starter
WarEagle1 #1334346 Tue Nov 19 2019 03:52 PM
ace skiver
I think they did (in light trucks, at least).
I’ll check the 1959 Specifications Manual.
Do you know where to find Specifications Manuals?
If not, I think there is a Tech Tip about documentation - it most likely has a link.
Tim
Re: Stomp starter
WarEagle1 #1334347 Tue Nov 19 2019 03:56 PM
ace skiver
page 21 in the 1959 Chevrolet Truck Specifications manual
Also, see that the trucks with solenoid starters had a 3-position ("modern") key/ignition switch.
Tim
Re: Stomp starter
WarEagle1 #1334357 Tue Nov 19 2019 05:28 PM
Yes I see that. That tells the tale. Thanks very much
Moderated by  Woogeroo
