The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (593ETow, BretStone, Beast57, 48bigtrucks, 3B, 59 fleet), 80 guests, and 3 robots.
Forums50
Topics119,504
Posts956,885
Members43,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Unexpected Engine Rev at Stop in Gear
#1334226 Mon Nov 18 2019 05:48 PM
DES57 Offline OP
Hey guys,
I have a ‘57 3200 with a rebuilt 350, topped with Carter AFB Competition Series 9635S, pushing a TH350 tranny. On occasion, it surprises me at a stop sign with an engine rev of probably 1000 rpm. A quick shift into neutral drops it back to normal. Does this sound like a vacuum problem or could it be transmission related?
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated
Re: Unexpected Engine Rev at Stop in Gear
DES57 #1334389 Tue Nov 19 2019 11:28 PM
3B Online
Hy DES57, welcome, I can honestly say that never in all my years have I heard of such a symptom. I wouldn't put something like this past a confusilator controlled engine, but a carbureted one? You say when you shift the transmission into neutral the engine returns to idle, no load on the engine and the r.p.m. goes down??? Does this occur as you're coming to a stop or after you're actually stopped? I'll be very interested to follow this thread.
3B #1334411 Wed Nov 20 2019 01:33 AM
DES57 Offline OP
It occurs while stopped for 10-20 seconds with my foot firmly placed on the brake and my hand on shifter, ready to throw it in neutral. I have a three mile drive to town at 45 mph so it’s typically warmed up. Just this week I discovered an open vacuum connection so I plugged that but haven’t had a chance to see if that made a difference. I have the door panels off to upholster them myself. This past spring I had a/c, ps, tilt column, parking brake, and exhaust installed. After four years, this is my first year to actually start driving it. Just building a daily driver. Any suggestions appreciated.
1957 Chevy 3200
3B #1334412 Wed Nov 20 2019 01:35 AM
DES57 Offline OP
1957 Chevy 3200
DES57 #1334414 Wed Nov 20 2019 01:41 AM
Big Bolt Forum Moderator
power brakes? that could change the vacuum when you come to a stop, which could change idle a bit but I would not think that much. It may be that he vacuum leak you fixed will solve your problem. I would take it for another test drive and see!
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
DES57 #1334557 Thu Nov 21 2019 01:48 AM
DES57 Offline OP
Update: Ran some errands today and it still revved up at the first traffic signal. My fixed vacuum leak didn’t change anything. I’m wondering if something from the transmission is affecting it. PO rebuilt engine and transmission. Also, no power brakes.
1957 Chevy 3200
DES57 #1334584 Thu Nov 21 2019 04:41 AM
Is there a vacuum line going to the transmission?
DES57 #1334589 Thu Nov 21 2019 05:02 AM
Boltergeist
Check your motor mounts. The engine could be shifting around enough at a stop to pull on the throttle linkage.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
DES57 #1334982 Sat Nov 23 2019 05:36 PM
DES57 Offline OP
There is a vacuum hose from Carter 9635s carb to the TH350 transmission. Motor mounts appear tight and not cracked. Took another drive today and it did not lunge/surge. A little cooler out at only about 35 F. When I get time I’ll see if it will stay running with the warm idol dropped a tad. No tach, but I’m guessing it’s about 900 now.
1957 Chevy 3200
DES57 #1335048 Sun Nov 24 2019 03:48 AM
Check to see if the diaphragm to which the vacuum line is attached is not ruptured. You can use a Mitey-vac or your mouth on the hose. It should hold vacuum until next Tuesday if its good.
Page 1 of 2 1 2
Moderated by  Woogeroo
