The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (DennisM, 3B, coilover, Johnny N, fclaridge, DES57), 140 guests, and 3 robots.
Forums50
Topics120,482
Posts965,699
Members43,682
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: Bench Grinder
HandyAndy #1334221 Mon Nov 18 2019 05:07 PM
4100 Fire Truck - The Klixon start relays are sealed units...correct? You mentioned cleaning contacts? There should be relays available out there to get you up and running. They don't make bench grinders like that anymore.
Re: Bench Grinder
4100 Fire Truck #1334270 Mon Nov 18 2019 11:10 PM
Originally Posted by 4100 Fire Truck
My grinder does not have, or use a capacitor.
My bad. So it's a split winding motor, rather than capacitor start.
The Klixon relay is a bit pricey, but you should be able to find a direct replacement. Here's one source: Klixon 4CR series relays
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Bench Grinder
4100 Fire Truck #1334362 Tue Nov 19 2019 06:52 PM
My grinder does not have, or use a capacitor. It uses a Klixon 4CR starting relay in series with the start/run windings. It also needs to be an exact match for the motor size too. I don't know if I want to go to the trouble to find a pricy replacement and have it still not work.
Pulled it back apart today to troubleshoot with my meter. Good thing I didn't buy a relay. The start winding was open. Guess I'll spin start it and start shopping for another good used one, instead of a cheap new one. I really like the 3/4hp 8 inch size. Not too big, not too small.
I just came up with an easy way to spin start it. Took a 3 in wire wheel in my cordless drill and held it up to the wire wheel on the grinder to bring it up to starting speed, and flip the switch and away it goes.
Re: Bench Grinder
HandyAndy #1334369 Tue Nov 19 2019 09:42 PM
We are lucky here in Southern Maryland, we have an electric motor shop that handles these small jobs. I took my locked up swimming pool pump motor in and they checked it out and added new seals and a bearing and the bill was $33.00.
Check your area to see if you have a motor shop that can help.
Mike B smile
Re: Bench Grinder
HandyAndy #1334374 Tue Nov 19 2019 10:12 PM
Hope your using a face shield...but then again that jump start method sounds risky. A wire spinning wheel engaging into another non spinning wire wheel.....hello? Hate wire wheels....had a piece of wire removed from the cornea of my right eye awhile back. Got lucky....healed w/o any significant vision loss.
Re: Bench Grinder
Phak1 #1334660 Thu Nov 21 2019 07:32 PM
Originally Posted by Phak1
I don't have any experience with a variable speed bench grinder like the Shopfox and I can see pros and cons. Would that speed controller be hard on the motor windings? I can purchase the 8" Jet thru NAPA for $250.00. I'm still searching Craig's List..........
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Re: Bench Grinder
HandyAndy #1334694 Thu Nov 21 2019 11:41 PM
I found an exact new looking match with a cast stand for my dead 3/4hp Craftsman for $150, but it's like 500 miles away.
Re: Bench Grinder
HandyAndy #1334797 Fri Nov 22 2019 02:58 PM
Boltergeist
As more and more vocational shops in high schools get closed down, it's possible to find very high quality, lightly used professional-grade tools and equipment at fire sale prices from the local school system surplus property departments. I've seen grinders, welders, wood and metal working equipment and even lathes and milling machines go for virtually scrap iron prices. Once us old geezer mechanics, machinists, welders, plumbers and woodworkers pass on, there won't be many young folks coming along to take our places. They're not being trained in any significant numbers.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Bench Grinder
HandyAndy #1334841 Fri Nov 22 2019 06:58 PM
Not many, but some will find a way. Some youngsters are born with a curiosity of how things were done before they showed up! And hopefully, they are smart enough to go find a library that hasn't closed down to study up on the subject!!
Page 3 of 3 1 2 3
Moderated by  48bigtrucks, MNSmith
