The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (TPR57C), 94 guests, and 3 robots.
Forums50
Topics119,424
Posts956,170
Members43,396
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Ignition timing (again)
#1334216 Mon Nov 18 2019 04:53 PM
Guys, bear with this rookie - trying to understand vacuum and centrifugal advance. Is there anytime when the truck is on the road that vacuum advance AND centrifugal advance are not engaged at all? At idle, vacuum advance is engaged, correct?
Thank you
Re: Ignition timing (again)
WarEagle1 #1334219 Mon Nov 18 2019 05:02 PM
Boltergeist
No, that's wrong. At idle neither vacuum nor centrifugal advance is a factor- - - - -"initial" timing only. Just off-idle the vacuum starts to come in, based on throttle opening and engine load. Centrifugal advance is engine speed related only- - - -the higher the RPM, the more advance comes in until the advance weights reach the limit of their travel (around 2500 RPM or so). The only real purpose for vacuum advance is fuel economy. At high speed, light throttle cruise, the ported vacuum adds around 8-10 degrees of advance above centrifugal. Anytime a load goes on the engine that drops manifold vacuum, the vacuum advance goes away and you're left with initial + centrifugal for load pulling or passing power. Back off the throttle, and the vacuum advance returns.
Industrial and heavy truck engines usually don't have vacuum advance at all, since they're run at or near full load most of the time and fuel economy isn't a factor.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
