The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Torjust, Bud Rod), 66 guests, and 3 robots.
Forums50
Topics119,467
Posts956,550
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
65 C10 with TH350 shift linkage problem
#1334217 Mon Nov 18 2019 04:53 PM
creating memories
Hey folks. I've got a 1965 C10 that has had a 350/350 installed. When I purchased it, it had a floor shifter, but I decided to put a tilt column with a column shifter in it. I thought I'd step out and put a nice one in so I purchased a Flaming River polished tilt column. The column came with a Lokar shift linkage that was supposedly correct for my installation. Long story short, the wiring was a disaster and I eventually had to cut out their "GM" plug because when it moved the connections were lost. Anyway, I finally got what I thought was the shift linkage adjusted only to discover it's backwards. In other words, when in park the column indicator shows 1. The obvious solution is to flip the arm on either the transmission or the column. Unfortunately, there isn't clearance at either end. The column arm would hit the inner fender and the transmission end would hit what I believe was the original crossmember. I called Flaming River tech support, they were worthless, had no idea at all. Next I tried Lokar and they weren't much better. Told me they didn't have anything for my application.
I can't believe I'm the first one to do this so I'm reaching out to you guys to see what you think. Possible option is to cut out the original crossmember for clearance at the transmission but that seems really drastic and I don't know if the original crossmember needs to stay for support. It is not connected in anyway to the transmission.
Another option would be to make some kind of bell crank to get the actuator action reversed.
Another option wold seem to be some kind of flex cable to get around behind the transmission arm and move it in the correct direction.
Like I said, I can't be the first to do this. What have you all done?
Re: 65 C10 with TH350 shift linkage problem
Larry's65 #1334246 Mon Nov 18 2019 08:30 PM
creating memories
Did some searching on the Internet and found a 5' flexible cable from JEGs that will probably work. I would have to fabricate brackets, but that's not a big deal. What do you think, flexible cable or cut out the old crossmember?
Larry's65 #1334250 Mon Nov 18 2019 09:49 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Did you put a new crossmember at the transmission tail housing? If so, you may be able to remove the original or modify it w/o any problem.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Justhorsenround #1334300 Tue Nov 19 2019 02:35 AM
creating memories
Yes, Martin, the TH350 has a different crossmember at the tail shaft. It seems like it might be okay to remove the original that is in the way, I just don't want to jeopardize the structural integrity of the frame. I want to be sure before I cut it.
Larry's65 #1334302 Tue Nov 19 2019 02:43 AM
I removed the one on my ‘62 C-10 after putting in a new one at the tail shaft mounting position on the 700R4. No problems.
Justhorsenround #1334344 Tue Nov 19 2019 03:47 PM
creating memories
OK, thanks. The transmission pan is partially covered by that old crossmember so removing it will make that more accessible as well. An extra bonus.
Larry's65 #1334349 Tue Nov 19 2019 04:01 PM
Exactly.
Larry's65 #1334728 Fri Nov 22 2019 02:47 AM
creating memories
Cut the crossmember out. It was difficult with the exhaust in the way, but I got most of it out, at least enough to clear the shift linkage and transmission pan interference. Hoping to get her on the road shortly. Fingers crossed! It seems like I've been here a lot, almost...
Larry's65 #1335409 Wed Nov 27 2019 03:14 AM
creating memories
First road trip yesterday! Felt great to have her out on the road again. A few things to sort out before I feel like I can drive her regularly. Pulled her back int he garage and added the rear sway bar I bought and working on installing the front one. This has got power steering from I assume a car on it and it interferes with the sway bar. Making a few modifications to get it to work.
Larry's65 #1338413 Fri Dec 20 2019 01:42 AM
Larry, I have a 1965 That I'm putting a small block/ 700r in. Does yours have the same motor mounts that was used on the 6 cylinder and how much clearance do you have between transmission and lip on cab in tunnel? Thanks for any infomation
Moderated by  Hambone
