The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (52Carl, ESum, cmayna, 5 Window 9434, carbking, 1 invisible), 138 guests, and 4 robots.
Forums50
Topics120,484
Posts965,711
Members43,683
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Bench Grinder
HandyAndy #1332623 Tue Nov 05 2019 02:41 AM
Boltergeist
Mauser rifles have a buttress thread where the gas shield fits into the back end of the bolt. I've got a special tool bit stashed away ground to turn that thread when I need to fabricate a copper heat sink to protect the threads when I'm welding on a custom bolt handle. The thrust bearing face of the thread is angled at 5 degrees, and the other side is 45 degrees. The thrust of lifting the bolt handle and compressing the firing pin spring is carried by the flatter angle. There's no really good reason for it, as other, less sophisticated rifles use a conventional 60 degree V thread on the bolt parts, but Paul Mauser over-engineered everything about his designs- - - - -way back in the late 1800's!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Bench Grinder
HandyAndy #1333707 Thu Nov 14 2019 01:40 AM
I have had great luck with my old craftsman “block grinder”. I bought it used and cleanedxit up and replaced the cord. Its from the 60’s and runs great all the time.
Re: Bench Grinder
Barnfind49 #1333748 Thu Nov 14 2019 02:20 PM
And it looks cool... cool
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Re: Bench Grinder
HandyAndy #1333772 Thu Nov 14 2019 04:59 PM
Jack of all Trades, Master of None
It’s all metal too, not like today. Nice find!
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Bench Grinder
HandyAndy #1333776 Thu Nov 14 2019 05:14 PM
I've been trolling Craig's List..........
If this was complete, I'd go get it!
CRAFTSMAN
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Re: Bench Grinder
HandyAndy #1333892 Fri Nov 15 2019 04:54 PM
Boltergeist
still using my reconditioned bench grinder i bought in 1976.............3/4 hp craftsman.......now watch it die since i bragged on it!
Pictures in my Photobucket
52 Chevy Panel
Re: Bench Grinder
Achipmunk #1333907 Fri Nov 15 2019 06:37 PM
That's my LUCK... dang
Craig
Q:"What yah runnin"
Re: Bench Grinder
HandyAndy #1334149 Mon Nov 18 2019 01:06 AM
Weird, my 3/4hp 8 inch Craftsman grinder I bought used 30 years ago died yesterday. It uses an obsolete starting relay that I tried to repair by cleaning the contacts, but it still won't go unless I give the wheels a good spin to get it moving. I hate to give up on it, but maybe it's time for a newer one after I get tired of spin starting it.
Re: Bench Grinder
4100 Fire Truck #1334166 Mon Nov 18 2019 02:56 AM
The capacitor has crapped out on it. That relay runs power thru the capacitor for starting, then takes it out of the circuit. Is there a cylinder on the side of the motor or maybe under the base? That's the start capacitor.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Bench Grinder
HandyAndy #1334203 Mon Nov 18 2019 03:09 PM
My grinder does not have, or use a capacitor. It uses a Klixon 4CR starting relay in series with the start/run windings. It also needs to be an exact match for the motor size too. I don't know if I want to go to the trouble to find a pricy replacement and have it still not work.
Page 2 of 3 1 2 3
Moderated by  48bigtrucks, MNSmith
