The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 71 guests, and 3 robots.
Forums50
Topics119,494
Posts956,794
Members43,417
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1964 327 V8 question
#1333950 Sat Nov 16 2019 02:14 AM
I plan to install a 1964 327 V8 into my 1957 Chevy NAPCO truck. The engine appears to be a1964 truck engine based on the numbers. I’m trying to find out if this engine originally had an alternator or a generator. Any ideas of where to look are appreciated.
Larry
Re: 1964 327 V8 question
LAJones48 #1333952 Sat Nov 16 2019 02:21 AM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1333957 Sat Nov 16 2019 02:45 AM
Great idea. Thanks!
LAJones48 #1333962 Sat Nov 16 2019 03:06 AM
Boltergeist
I'm pretty sure 63 was the first year for alternators, the ones with a 4-connector external regulator. Those things are a royal pain in the butt to work with. Unless you're building something that's supposed to look factory original, a 10-SI internal regulated alternator from the middle 1970's or newer would be a much better choice, reliability-wise.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
LAJones48 #1333963 Sat Nov 16 2019 03:12 AM
Thank you. I’m trying to stay period correct, but it will be a driver and get used as originally intended so I’m okay with upgrades.
LAJones48 #1334063 Sun Nov 17 2019 06:42 AM
I hope that you are planning staying out of the gas pedal. 327s are short stroke engines and rev up real fast. You have 4 u-joints and a transfer case designed to handle a low RPM 125 HP inline six 235.
I am not trying to dissuade you from doing your swap, I just know a guy with a '57 NAPCO who went with a 300 hp 350 crate motor and could not keep the bearings in the transfer case or was blowing out U-joints.
Granted, he could not keep his foot out of the gas.
LAJones48 #1334085 Sun Nov 17 2019 03:52 PM
Hi Carl. Thank you for the warning. I do understand the risks involved with running the 327. There was a guy many years ago in our area who put a 389 in his GMC version of a Cameo that was also a NAPCO conversion. He was known for destroying the spider gears in his rear differentials by doing burnouts. I had a 1958 GMC factory NAPCO Carryall that had a 389 installed after the 336 wore out. I never had any problems other than keeping the fuel tank full. This is a truck version of the 327, 2 bolt mains, focus on low rpm torque etc. I’m 71 years old so I probably won’t get too crazy with the skinny pedal. Again, I do appreciate you advice.
Larry
LAJones48 #1334441 Wed Nov 20 2019 04:48 AM
Can't wait to see some pictures, Larry, better yet, I'd like to hear it run. I love the sound of those short stroke bumblebee engines.
LAJones48 #1334443 Wed Nov 20 2019 04:59 AM
Boltergeist
You'd love the short stroke screamer I've got on the drawing board- - - - -a 305 block with a destroked 283 crankshaft- - - -a 2 7/8" stroke crankshaft in a 305 block gives a displacement of 250 cubic inches- - - - -sort of like a bumblebee on steroids!
LAJones48 #1334510 Wed Nov 20 2019 08:07 PM
HRL, I would love to see that built. I have always thought about a built 305 or 307. I had a 305 with a Crane version of the Duntov 30/30 cam, it sounded nasty.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Page 1 of 2 1 2
Moderated by  Woogeroo
