The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (Christian, 50Chevy3100, dirtball, DennisM, 49 3100, carbking), 93 guests, and 3 robots.
Forums50
Topics119,469
Posts956,559
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Is this the 235 to swap?
#1334044 Sun Nov 17 2019 03:21 AM
Tony292 Offline OP
https://www.facebook.com/marketplace/item/2367551886819053/
Is this 61 235 the good one to swap in place of a 1940 216? Seems like a good price.
Re: Is this the 235 to swap?
Tony292 #1334048 Sun Nov 17 2019 03:33 AM
ace skiver
Hard to determine.
A shiny "pig-in-poke"!
Glossy paint job, but, "The outside is cleaned and painted but i haven't done anything with the inside it ran when i took it apart to clean it."
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Tony292 #1334051 Sun Nov 17 2019 03:40 AM
Boltergeist
That's what's known as a "rattle can rebuild". Basically, you're buying a paint job. The price is at least twice what I'd offer, possibly three times. Unless you can hear an engine run it's a "rebuildable core" and you should offer an appropriate price.
Pros:
61 is one of the most recent manufacture 235's- - - -they stopped installing them in either 61 or 62, depending on who you ask. It will have the 848 casting number cylinder head, which has a higher compression ratio than 56 and earlier engines. If it's out of a car, it's probably got hydraulic valve lifters. That can be good or bad, depending if the lifters work properly.
Cons:
The low-mount water pump won't work well with the 1940 radiator. The fan sits too low and might hit the lower radiator hose. You'll probably need to install a pump relocation plate to be able to use the 216 style water pump. Unless the owner is willing to provide the intake and exhaust manifolds, carburetor, generator, distributor and starter in the purchase price, you'll end up spending big bucks rounding up enough accessories to complete the project. That one's a $200.00 maximum engine in my neighborhood.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Tony292 #1334052 Sun Nov 17 2019 04:43 AM
We used to call them spray can rebuilds, beware of the engine that has had no work and looks shiny painted, should be considered to blow nice blue smoke. Unchecked engines should get no more than core value.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Tony292 #1334061 Sun Nov 17 2019 06:22 AM
It sure is purty. Too bad the paint will be destroyed by the hot tank that your engine rebuilder will need to do before he rebuilds the engine for you.
Tony292 #1334095 Sun Nov 17 2019 05:26 PM
I bought one similar to this (Complete) for $250. Seller said it was .010 over ran good when pulled ect...I opened it up it was .080 over with very bad cylinder walls...unless you run it or open it it's like a Cracker Jack prize (Unknown). Luckily the carburetor, started & generator were good. Also the Intake/exhaust. The head was "848" and not cracked. Those were worth the $ but I was out a block.
Tony292 #1334096 Sun Nov 17 2019 05:33 PM
Boltergeist
That 80 over block would be a good candidate for six sleeves and a set of STD. bore pistons. I used to do that with "junk" racing blocks my competitors were throwing away. Eventually they figured out they were getting beat with their own discards! My students needed blocks to practice machining on, and the guys who sponsored my race engine building program appreciated the chance to get a race-prepared block at a bargain price!
Tony292 #1334439 Wed Nov 20 2019 04:44 AM
Yep, and all you need is a $80,000.00 worth of machine equipment and tools (used prices), and a HRL to run the equipment, but I think they quit making those a long time ago. smile
Carl
Tony292 #1334480 Wed Nov 20 2019 04:28 PM
"had the exhaust manifold powder coated"...does he have the rest of the missing engine parts not in the photo?
52Carl #1334483 Wed Nov 20 2019 05:24 PM
Boltergeist
Carl
Hmmmm- - - - -I guess my $750.00 used Van Norman boring bar and a 3 lb. BFH to drive the sleeves in with won't make the cut. Please don't tell all those blocks I salvaged with that setup that they won't work- - - - - -I'd hate to have to give all those winnings back!
Page 1 of 2 1 2
Moderated by  Woogeroo
