The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Christian, OhioJones), 82 guests, and 3 robots.
Forums50
Topics119,467
Posts956,550
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Gas/Water Separator
#1333877 Fri Nov 15 2019 03:30 PM
I was wondering if a Gas/Water Separator was a common accessory added to the fuel line of an old Stovebolt? If so, where did you mount it and how often does it show water in the fuel?
Thanks for any replies.
Re: Gas/Water Separator
WarEagle1 #1333881 Fri Nov 15 2019 04:04 PM
Boltergeist
The glass bowl fuel filters with the ceramic strainer would act as a water trap. It wasn't the primary purpose of the glass bowl, just a nice side effect of the moisture settling to the lowest point in the fuel flow. In cold, high humidity situations the moisture in the air would condense and end up as liquid water in the fuel tank. The old advice about keeping the tank close to full in cold weather was actually a pretty good idea.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
WarEagle1 #1333887 Fri Nov 15 2019 04:36 PM
Sta-Bil....great stuff. Especially...during winter lay-up.
WarEagle1 #1333893 Fri Nov 15 2019 04:55 PM
Does Sta-Bil somehow remove water from the fuel?
WarEagle1 #1333894 Fri Nov 15 2019 05:05 PM
I believe that it causes the water to blend with the gas. Much like alcohol (or Heet that was in common use in Alaska back in the 70’s) does.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
WarEagle1 #1333895 Fri Nov 15 2019 05:09 PM
10-4 thanks
Moderated by  Woogeroo
