The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
24 members (DaveV, Fred Jones Jr, arustycars639, 3800GUY, fonz8261, Apatrick, 2 invisible), 123 guests, and 3 robots.
Forums50
Topics120,493
Posts965,751
Members43,684
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Engine Identify
#1333571 Wed Nov 13 2019 02:48 AM
I bought this motor and was told it was a 235. The motor has no casting numbers on the block, only the two captain bars above the starter. I know the captain bars are from 261 motors The only numbers are by the distributor, But I can't decode it
Re: Engine Identify
1935Masterdeluxe #1333578 Wed Nov 13 2019 04:07 AM
Boltergeist
The LAQ prefix is for a 1953 235 with a powerglide transmission. Check this website:
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
Captain's bars don't always mean you've got a 261. The only way to know for sure is to remove the cylinder head and measure the bore size. 235's have a 3 9/16" bore. 261's have a 3 3/4" bore. Both engines have the same stroke, 3 15/16".
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Engine Identify
1935Masterdeluxe #1333593 Wed Nov 13 2019 12:37 PM
ace skiver
In case you want/need confirmation on HrL's correct information, here is the GM/Chevrolet info/document showing the LAQ serial-number code-preface.
If you want/need further confirmation, post the head & block casting-codes & block date casting-codes.
The "captain bars" over the starter is on that 235 (car-Powerglide) block (with hydraulic lifters). No truck 235s came with hydraulic lifters.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Engine Identify
1935Masterdeluxe #1333608 Wed Nov 13 2019 03:20 PM
My Blog
Re: Engine Identify
Pre '68 Dave #1333609 Wed Nov 13 2019 03:25 PM
ace skiver
That link did not work for me, Dave
Here is your blog site.
Identifying a 1953 235
Tim
Re: Engine Identify
tclederman #1333610 Wed Nov 13 2019 03:26 PM
That's the problem, for some reason this motor does not have a casting number on the engine block?
Re: Engine Identify
1935Masterdeluxe #1333611 Wed Nov 13 2019 03:28 PM
ace skiver
1935Masterdeluxe,
Are you referring to the Engine Serial Number, or, referring to the head and block casting codes at the locations indicated at the link in my post above?
Tim
Re: Engine Identify
1935Masterdeluxe #1333623 Wed Nov 13 2019 04:46 PM
The block does not have a casting number. Only the serial number by the disturbrator. The head does have a casting number. It's a 848 head
Re: Engine Identify
1935Masterdeluxe #1333626 Wed Nov 13 2019 04:52 PM
Wow I just read on it, so it mite be a 53 235. I'll need too read more on it thank you
Re: Engine Identify
1935Masterdeluxe #1333633 Wed Nov 13 2019 05:30 PM
Check way down low on the R.H. side near the fuel pump just above the oil pan.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Page 1 of 2 1 2
Moderated by  Woogeroo
