The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (Jerry M., coilover, joronabell, David C., D B Cooper, 42465967, 1 invisible), 375 guests, and 3 spiders.
Forums48
Topics117,309
Posts937,979
Members42,896
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Engine Identify #1333571 Wed Nov 13 2019 02:48 AM
1935Masterdeluxe Offline OP
I bought this motor and was told it was a 235. The motor has no casting numbers on the block, only the two captain bars above the starter. I know the captain bars are from 261 motors The only numbers are by the distributor, But I can't decode it
Re: Engine Identify [Re: 1935Masterdeluxe] #1333578 Wed Nov 13 2019 04:07 AM
Hotrod Lincoln Offline
Boltergeist
The LAQ prefix is for a 1953 235 with a powerglide transmission. Check this website:
http://1954advance-design.com/Stovebolt-engine/casting-numbers.html
Captain's bars don't always mean you've got a 261. The only way to know for sure is to remove the cylinder head and measure the bore size. 235's have a 3 9/16" bore. 261's have a 3 3/4" bore. Both engines have the same stroke, 3 15/16".
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Engine Identify [Re: 1935Masterdeluxe] #1333593 Wed Nov 13 2019 12:37 PM
tclederman Offline
Boltergeist
In case you want/need confirmation on HrL's correct information, here is the GM/Chevrolet info/document showing the LAQ serial-number code-preface.
If you want/need further confirmation, post the head & block casting-codes & block date casting-codes.
The "captain bars" over the starter is on that 235 (car-Powerglide) block (with hydraulic lifters). No truck 235s came with hydraulic lifters.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Engine Identify [Re: 1935Masterdeluxe] #1333608 Wed Nov 13 2019 03:20 PM
Pre '68 Dave Offline
My Blog
Re: Engine Identify [Re: Pre '68 Dave] #1333609 Wed Nov 13 2019 03:25 PM
tclederman Offline
Boltergeist
That link did not work for me, Dave
Here is your blog site.
Identifying a 1953 235
Tim
Re: Engine Identify [Re: tclederman] #1333610 Wed Nov 13 2019 03:26 PM
That's the problem, for some reason this motor does not have a casting number on the engine block?
Re: Engine Identify [Re: 1935Masterdeluxe] #1333611 Wed Nov 13 2019 03:28 PM
tclederman Offline
Boltergeist
1935Masterdeluxe,
Are you referring to the Engine Serial Number, or, referring to the head and block casting codes at the locations indicated at the link in my post above?
Tim
Re: Engine Identify [Re: 1935Masterdeluxe] #1333623 Wed Nov 13 2019 04:46 PM
The block does not have a casting number. Only the serial number by the disturbrator. The head does have a casting number. It's a 848 head
Re: Engine Identify [Re: 1935Masterdeluxe] #1333626 Wed Nov 13 2019 04:52 PM
Wow I just read on it, so it mite be a 53 235. I'll need too read more on it thank you
Re: Engine Identify [Re: 1935Masterdeluxe] #1333633 Wed Nov 13 2019 05:30 PM
BC59 Offline
Check way down low on the R.H. side near the fuel pump just above the oil pan.
BC
1960 Chevy C10 driver
G.M dealer tech since 1980 & counting
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
