The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Johnny N, RustYardDog, DennisM, Jon G, Phak1, New_Ton), 241 guests, and 4 robots.
Forums60
Topics123,387
Posts995,752
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Help with year
#1332794 Wed Nov 06 2019 09:17 PM
Tazdog Offline OP
New to this. Will someone tell me the year and any other info from this vin off a gmc panel wagon 101-22-S-17030
Re: Help with year
Tazdog #1332800 Wed Nov 06 2019 10:30 PM
Here is a GMC serial number decoder.
Try to decode your number - post your finding here and we will confirm.
GMC and Chevrolet used the term Panel Truck for that body style on a truck chassis.
I think Panel Wagon is more commonly used for the Sedan Delivery body - for that body style on a car chassis.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Help with year
Tazdog #1332813 Thu Nov 07 2019 12:48 AM
Tazdog Offline OP
I think it is a 1951
Re: Help with year
Tazdog #1332871 Thu Nov 07 2019 02:57 PM
Good job, Tazdog
101-22-S-17030
101 = 10 = 1/2 ton
1 = short bed
22 = 228 engine (standard engine)
S = St. Louis assembly plant
17302 = 16302 th truck off the assembly line that year
Post the engine serial number that is pressed into the block at the rear of the distributor.
You also might want to join this discussion board.
If you do not get a response, send me a Private Message.
Tim
Re: Help with year
Tazdog #1332884 Thu Nov 07 2019 04:35 PM
Tazdog Offline OP
Thank you for confirming
Re: Help with year
Tazdog #1333059 Sat Nov 09 2019 01:28 AM
1951 was unique for GM pickups in that it was the only year with door vent windows and twist down door handles. 1950 had no vent windows and 1952 had push button door handles.
Evan
Re: Help with year
coilover #1333439 Tue Nov 12 2019 07:07 AM
Unless, as in my case, some previous owner has changed the doors...
1951 Chevy Panel Truck
