The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (Hotrod Lincoln, Donf, Doc.Hall, Hophouse, Flatblu4748, 3B, 1 invisible), 148 guests, and 3 robots.
Forums50
Topics118,974
Posts952,317
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: Sway Bar Sugestions ??
marzach #1117438 Wed Aug 05 2015 01:14 AM
I went to the CPP website and they have installation instructions for what looks to be every piece of equipment they sell.
marzach #1117493 Wed Aug 05 2015 09:47 AM
Yep, install instructions for Advance Design trucks:
http://www.classicperform.com/tech_articles/SwayBarChevyTruck/SwayBarChevyTruck.htm
Tks
Denny Graham
Sandwich, IL
marzach #1119862 Wed Aug 19 2015 03:49 PM
marzach Offline OP
Bowtie Bits LLC --- bowtiebits.com --- has the same swaybar for $139.00 {AD-475-CP179} plus shipping.
marzach #1333017 Fri Nov 08 2019 06:56 PM
Shop Clutterist
I installed the CPP sway bar kit earlier this week. Makes a big difference.
I encountered a few issues with the kit.
Two of the supplied bolts were supposed to be 1 3/4" long grade 5. The kit came with 2 3/4" long grade 8 bolts. (1" too long) No big deal - I happened to have some spare bolts of the correct length on hand.
The instructions do not mention the shock mounts. The shock mounts attach to the same axle U bolts that the plates for the new bar's links attach to. You have to remove the shock mounts and sandwich the plates between the axle and the shock mounts.
The holes in the plates that attach to the U bolts were poorly drilled. Simply re-drilling them on the drill press did not help as the spacing between them was out by at least 1/8". I had to elongate one hole with a file to correct the spacing. I used the shock mount as a template to mark where the hole should be.
No insurmountable issues, really.
Gord
1954 1/2 ton 235 4 speed
marzach #1333024 Fri Nov 08 2019 08:14 PM
Good job Gord!
Page 3 of 3 1 2 3
Moderated by  SWEET
