The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (DS1957GMC, 3B, Hotrod Lincoln, DennisM, 2 invisible), 196 guests, and 3 robots.
Forums50
Topics121,036
Posts970,291
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Engine Installation Advice
Gray_Ghost #1332939 Fri Nov 08 2019 01:16 AM
Sorry, but it's going to take a bit more than 6 minutes to replace it. It honestly wasn't that bad though. The worst part was dealing with the fender welting I added between the cab and fenders.
I have a couple suggestions, assuming your front end is pretty well aligned right now. Don't loosen any bolts except those needed to remove the clip. On the support rods, either mark the location of the nuts, or leave the rear nut in place as I did. Then when you put the clip back on, leave all the bolts a little loose. Use the support rods to pull the clip up into place before tightening everything. I left the support rods in place, so I'm not sure how much play there is in the rear mounting holes, but regardless I think this would work. They do interfere a little with the inner fenders when you remove the clip, but it wasn't that bad to work around them.
The biggest problem is all the little side projects you're going to want to do with the clip removed.
Greg Brown
'49 Chevy 3100
Gray_Ghost #1332955 Fri Nov 08 2019 03:51 AM
I have removed & set in engine and transmission together twice in my '53 without removing front clip. Remove hood, radiator, and radiator support frame. Remove the shroud with the hood latch. The grille stays in place. Inside the truck, remove the center floor pan, which permits you to lift and guide the back of the transmission into place.
Gray_Ghost #1332999 Fri Nov 08 2019 05:00 PM
We DON'T r&r engines with the front clip in place but if one feels they MUST then we made a tool that makes the job at least 80% easier. First: the lift bar
A piece of 2x3 rectangular tubing with 1/8 wall thickness. Holes are drilled to align with the rocker bolts/studs on a 235/216. The top surface of the tube has a hole big enough for a socket and extension to pass through. Extra holes pictured are for a Buick straight eight and Pontiac I6. Nuts on the underside of the bar keep the bar off the rocker assembly and multiple holes sideways through bar are for hoist hook chain adjustment.
[img]https://i.postimg.cc/YG47XbFq/engine-lift-bar-005.jpg[/img]
[img]https://i.postimg.cc/SnMY2fR8/engine-lift-bar-002.jpg[/img]
Procedure: Set hoist chain on lift bar so engine hangs nearly vertical.
Remove fan blade and water pump
Lower till rear of trans hangs on cross member and continue to lower till chain goes slack
Move chain to a balanced position and when raised engine will slide back into position by itself
Evan
Gray_Ghost #1333002 Fri Nov 08 2019 05:50 PM
I had thought about removing the front clip, but when I went under the truck to apply some penetrating oil, I noticed that the passenger side sheet metal was damaged by rust where it connects to the cab. This wasn't a huge surprise to me, as the inside of the cab is also rusted out where the fresh air heater would attach. I was hoping to leave everything untouched, as it seems to be firmly in place at the moment. Once I can make the truck move on it's own, I planned to address the metal repair. I need to be able to move the truck out of the garage to do this, as I'm sure that I would cause a fire in my garage with welding or grinding. Taking the front clip off isn't really the issue. Storing it while I get to everything is the issue. It's a sad reality for me, but I have no space in my garage for that. Maybe, once I install the engine, that floor space could store the clip. I'll have to think this through....
Thanks, though, for the suggestions!
Mike
1953 3100
1994 Chevy 1500 (Donated to charity 2016)
My Photobucket Pics
My Restoration Adventure Blog
Gray_Ghost #1333005 Fri Nov 08 2019 05:59 PM
I removed the front grill and supports along with the rad. I also used a load leveler . I am glad I had that tool.
1951 1 Ton Completed
truckernix #1333008 Fri Nov 08 2019 06:08 PM
I had wondered if that would work. I also have the load leveler. How bad was the angle and how much back and forth was required?
Mike
1953 3100
My Photobucket Pics
bartamos #1333443 Tue Nov 12 2019 12:13 PM
All of the rusted/stuck bolts either broken off or cut off. A few remaining bolts still there, but loosened, so the clip doesn't fall down. Hopefully I'll get the clip off and the engine installed this coming weekend.
Now, back to the original question: other tips, tricks, advice or pitfalls to avoid when I try to install the engine. Anything else?
Mike
1953 3100
My Photobucket Pics
Gray_Ghost #1333463 Tue Nov 12 2019 04:04 PM
Heating rusted or stuck bolts with a torch and letting them cool down, oil when still warm, will allow most to be easily removed as the heat loosens the rust.
Ed
Gray_Ghost #1333464 Tue Nov 12 2019 04:06 PM
V
I've done 2 engine/tranny swaps recently on AD trucks, a 235/3-speed with torque tube on a 49 Chevy 3100 and a 350/TH350 auto on a 49 GMC 100.
I documented them on youtube. Some are informational and helpful, some are rambling & probably not as engine swaps on AD's were new to me at the time. I figured it out as I went. It's not rocket science and if you have mechanical abilities you will be successful. Don't get in a hurry and address the problems/concerns as you encounter them, they'll be very evident if there.
Good luck
Dave
Gray_Ghost #1333507 Tue Nov 12 2019 07:53 PM
I agree, good tutorial Greg on removing front clip.
Back in 90 or 91 I removed the 235 in my 55-1st 3600 with the fenders in place. I removed hood, hood latch/ filler plate, radiator, core support and grille. That method worked okay, but if I had it to do again I would remove the front clip as a unit.
Professional Novice
Page 2 of 3 1 2 3
Moderated by  Woogeroo
