Stovebolt is pleased to support the Salvation Army! We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
16 registered members (Bill Marlow, D B Cooper, 6571, 49 3100, 03marauderman, 78buckshot, 1 invisible),
470
guests, and 4
spiders. |
Key:
Admin,
Mod
Forums48
Topics116,498
Posts930,005
Members42,646
Most Online940 Apr 5th, 2017
Re: Original leaf springs with a 350 engine
[Re: coilover]
#1333086
Sat Nov 09 2019 08:40 AM
OP
Coilover
Is the decent one a Fatman? I assumed all Mustang II's would require the semi-circle notch to be cut out of the frame for clearance issues. I haven't got that far yet so my investigation into them is very limited. In addition, I'm not a welder...are there M II's that are A., bolt-on, B., no-notch and C., decent?
[Re: Rocket man]
#1333093
Sat Nov 09 2019 12:43 PM
Boltergeist
I'm not Coilover, but yes, there are bolt-on M-II systems. Unless you do some custom fabrication while installing that type of independent front suspension, you'll end up with a truck that resembles a redbone hound after a close encounter with a skunk- - - - -nose dragging the ground as he tries to plow a furrow half a mile long! There are ways to avoid the "droop-snoot" look, but only by modifying the height of the M-II crossmember. That definitely requires welding and fabrication skills. Generally speaking, IFS "kits" are a good way to shovel sand down a rathole, dollar-wise! The "good" ones are horrendously expensive, and the cheap ones make you spend a lot of extra money making them safe and reliable. If you don't have a lot of experience building suspension systems from the ground up, you'll be much better off finding someone like Evan in your neighborhood and paying him to get the job done right the first time. Far too many of the hotrodded cars and trucks I have to share the road with are nothing but rolling death traps, and that includes some of the very high-dollar "resto-rods" that I inspect for potential buyers overseas. One guy from Australia keeps me busy- - - - -40-something inspections in the past 10 years- - - - - he's bought about half of them based solely on my photo shoots and test drives. He pays top dollar for this old geezer's opinions! Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
[Re: Rocket man]
#1333189
Sun Nov 10 2019 04:11 AM
No, the decent one could be from Chassis Engineering, Speedway, or in that price range. The bigger buck ones are from Fatman, Heidt's, etc. There are several that are bolt on and have steering rod boot clearance---Chassis Engineering come to mind. If a boot just rubs the bottom of the frame but is not flattened by the contact a little heat and a BFH will give the needed clearance. Of course the shoe makers kids go barefoot so my 34 Chevy with a Heidt's has been rubbing the boots for years. When one rubs through and starts dripping grease I'll expect everybody to feel sorry for me.
Evan
[Re: Rocket man]
#1333795
Thu Nov 14 2019 07:20 PM
I installed an IFS kit from No Limit Engineering on my '56 3100 and had no issues. It is well designed and and performs as advertised.
