The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Dragsix, glenns towing, 55 SHAKER, Oldngray, jmoore, 2 invisible), 105 guests, and 3 robots.
Forums50
Topics119,441
Posts956,318
Members43,403
Most Online1,229
Jan 21st, 2020
Image Posting Policy
re-dilling a flex plate
#1321715 Tue Aug 13 2019 02:42 PM
Over the past few months I've gathered together the parts needed to convert my broken 4 speed hydramatic to a 700R4., This included the Adaptor plate, the flat plate, flywheel and flex plate. But working with another trucker it was discovered that the oem holes in the flex plate are spaced futherout to line up with a torque converter, so with have to find the correct torque or can we redrill new holes on the plate?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Re: re-dilling a flex plate
Modelman #1322396 Sun Aug 18 2019 06:09 PM
Boltergeist
Buffalo Engineering sells a 700R4 flex plate that has been modified to fit the stovebolt crankshaft by welding a new center into the plate with the proper bolt pattern and re-balancing it. It's probably worth the cost to buy that one. It's got the correct starter ring gear to work with the stovebolt engine, also.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Modelman #1322467 Mon Aug 19 2019 03:36 AM
Your flex plate does not have a starter ring and I have never seen a starter ring on a 700R4 converter. Am I missing something?
Evan
Modelman #1322468 Mon Aug 19 2019 03:42 AM
Oops, re-read and saw flywheel (??) mentioned. If what you are calling a flywheel is an a/t flex plate with the starter ring I would think the double parts hung on the crank would cause starter mount problems. Keep us posted.
Evan
Modelman #1323068 Thu Aug 22 2019 11:30 PM
General Purpose
Drill it.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Modelman #1324946 Thu Sep 05 2019 02:39 PM
Ok Update. I have a torque converter being custom built from American Hot Rod Solution http://www.americanhotrodsolutions.com/ once I get that in today I''ll take it to a machine shop and have a simple round flex plate made to fit the crank bolt pattern and the torque converter, will post pictures and a write up for the trans switch.
Modelman #1329119 Mon Oct 07 2019 02:08 PM
Got the plate drilled and the Torque Conveter, not onto the TV Cable, Speedo Housing and cross members......
Modelman #1329126 Mon Oct 07 2019 03:54 PM
Jake,
There is no ring gear /flywheel gear for the starter to engage. The engine will not start, the starter will run, but it will not turn the engine.
Tommy
59 apache 1/2t
261 short stepside
Modelman #1329158 Mon Oct 07 2019 09:26 PM
yea what he said???
Modelman #1331914 Wed Oct 30 2019 03:07 PM
Tommy, on the 60+years, with the GMC 305 with the Automatics, the flex pate and fly wheel are two seperate parts, it confused me and others as well.
Moderated by  Hambone
