The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 registered members (carryall jerry, ESum, Drew54, Bill Trotter, 3 invisible), 377 guests, and 3 spiders.
Forums48
Topics117,294
Posts937,758
Members42,883
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: inner/outer cowl seperator [Re: klhansen] #1331802 Tue Oct 29 2019 07:58 PM
Mike Burns Offline OP
I really appreciate your help here. I'm just not quite sure what youre referring to as the A-pillar. In my mind, there is a pillar that the hinges bolt to,, which I've been calling the hinge pillar. Farther forward there is the bottom of the inner to outer cowl divider, which is shaped nearly the same as the hinge pillar. Is this what you're calling the A-pillar? If so, then I'm really confused because it has a hole in the bottom which lines up with the hole in the rocker. If I'm being dense, then I apologize. Thanks
Re: inner/outer cowl seperator [Re: Mike Burns] #1331803 Tue Oct 29 2019 08:18 PM
klhansen Offline
Standard terminology is that the most forward pillar is the A pillar, and lettered rearward from there.
So yes, the hinge pillar is the A-pillar and the B-pillar is the lock pillar. On a 4 door car, the B-pillar would be the front door lock pillar and the rear door hinge pillar (unless you're talking about a car that had suicide doors in the rear - 1948 Plymouth comes to mind - my sister fell out of ours when she tried to latch the door on the highway and the wind caught it and jerked her out - sorry for the excursion into left field wink ) The rear door lock pillar on a sedan would be the C-pillar.
Sorry for the confusion.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: inner/outer cowl seperator [Re: klhansen] #1331807 Tue Oct 29 2019 08:41 PM
Thank you so much. I'm sorry that I wasn't aware of the proper lingo in regard to the pillar designations. That clears it right up. Your information will help me tremendously. I can move forward a few steps now.
THANK YOU
Page 2 of 2 1 2
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.3
