The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
E V E N T Highlight
Southern
"STOVEBOLT"
Jamboree 2022
July 8 and 9
Lebanon TN
The Southern Bolters are planning their area get together in
conjunction with the
Southeast Truck Nationals at Cedars of Lebanon State Park (TN)
Check out the details, with new info on the Southern Bolters forum.
Plenty of other events in the Side Lot
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Hotrod Lincoln, Grandpas_48), 86 guests, and 3 robots.
Forums59
Topics128,010
Posts1,036,482
Members45,915
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Gentle heating, tapping shaft endwise, oil while cooling would be a start.
Ed
I will be replacing my head soon and sounds like I should use the Rimflex gasket. Does anyone have the part number? (I apologize ahead of time if it is in the Tech Tips).
I got my last Remflex for the 235 at Summit for a good price. That gasket was the cure for an old Clifford intake I had that didn't fit for spit.
https://www.summitracing.com/parts/rfl-2027/overview/
1946 1/2-Ton Chevy [stovebolt.com]
1953 Chevy 3/4-ton Factory Stakebed [stovebolt.com]
ED--I would add the use of PB blaster to aid in getting the flapper unstuck..Bill
JiMerit - thank you (belated) for the link to the Rimflex gasket.
Frozen up heat riser valves are a common problem, and they're usually pretty simple to fix. Heat from a Propane or Acetyline torch ,penetrating oil, tapping the shaft side to side with a hammer, and lots of patience will usually free up the shaft. Soak, heat, tap, repeat- - - - - - -over and over. Once it breaks free be sure the flap can move through its full travel, install a new thermal spring, and press on. The thermal spring on Ebay advertised for a Jeep is less than half price of the outrageously expensive OEM style ones the resto-ripoff places sell.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Page 2 of 2 1 2
Moderated by  Woogeroo
