The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (klhansen), 81 guests, and 4 robots.
Forums60
Topics126,102
Posts1,019,300
Members45,431
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 235 Exhaust manifold replacement
Oldtruckspapa #1331707 Tue Oct 29 2019 03:32 AM
Gentle heating, tapping shaft endwise, oil while cooling would be a start.
Ed
Oldtruckspapa #1331746 Tue Oct 29 2019 02:45 PM
I will be replacing my head soon and sounds like I should use the Rimflex gasket. Does anyone have the part number? (I apologize ahead of time if it is in the Tech Tips).
Oldtruckspapa #1331754 Tue Oct 29 2019 03:33 PM
I got my last Remflex for the 235 at Summit for a good price. That gasket was the cure for an old Clifford intake I had that didn't fit for spit.
https://www.summitracing.com/parts/rfl-2027/overview/
1946 1/2-Ton Chevy [stovebolt.com]
1953 Chevy 3/4-ton Factory Stakebed [stovebolt.com]
Oldtruckspapa #1331772 Tue Oct 29 2019 05:04 PM
ED--I would add the use of PB blaster to aid in getting the flapper unstuck..Bill
Oldtruckspapa #1335375 Tue Nov 26 2019 10:05 PM
JiMerit - thank you (belated) for the link to the Rimflex gasket.
Oldtruckspapa #1335378 Tue Nov 26 2019 10:20 PM
Frozen up heat riser valves are a common problem, and they're usually pretty simple to fix. Heat from a Propane or Acetyline torch ,penetrating oil, tapping the shaft side to side with a hammer, and lots of patience will usually free up the shaft. Soak, heat, tap, repeat- - - - - - -over and over. Once it breaks free be sure the flap can move through its full travel, install a new thermal spring, and press on. The thermal spring on Ebay advertised for a Jeep is less than half price of the outrageously expensive OEM style ones the resto-ripoff places sell.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
WAG MORE- - - - - -BARK LESS!
Page 2 of 2 1 2
Moderated by  Woogeroo
