The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (AwDang, 1953 panel, Johnny N, Dusty, Barnfind49, 1 invisible), 239 guests, and 3 robots.
Forums50
Topics120,034
Posts961,345
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 6 1 2 3 4 5 6
‘59 235 Low Oil Pressure
#1331649 Mon Oct 28 2019 11:49 PM
Phak1 Offline OP
Jack of all Trades, Master of None
I know that these old engines are notorious for being able to run with low oil pressure but my question is how low is too low. I’ve finally had a chance to put a few miles on my ‘52 Chevy with a 235 installed. It pegs the needle on the 30 lb. gauge when I first start it but falls to 15 lbs. when it warms up (180 degrees) and running at 35-40 MPH. At idle it drops to almost 0. There is no valve clatter from the hydraulic lifters and no other unusual noises.
I’m running 10w-30 Valvoline.
This seem unusually low to me. This engine was rebuilt in 2013 and then sat for 5 years before I got it.
Your thoughts!
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: ‘59 235 Low Oil Pressure
Phak1 #1331657 Tue Oct 29 2019 12:43 AM
How much oil does it burn? Try 10w40.
Phak1 #1331659 Tue Oct 29 2019 12:50 AM
Phak1 Offline OP
I haven’t driven it enough miles to tell if it is using oil. I don’t believe that it is burning oil because it doesn’t smoke and was rebuilt by a PO in a reputable shop. It came with the paperwork to prove it.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1331666 Tue Oct 29 2019 01:16 AM
possible inaccurate gauge. Id put 15w40 or 20w50 in it. See what gauge does then. Could try a different gauge also. Was the engine broken in or ever ran prior to you getting it?
Phak1 #1331667 Tue Oct 29 2019 01:17 AM
ace skiver
Heck, I’d try 20W50 oil - it is readily available and costs $20 (Walmart).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Phak1 #1331677 Tue Oct 29 2019 01:43 AM
Phak1 Offline OP
I don’t know if it was properly broken in because I didn’t buy it from the owner who had it rebuilt. That was two owners ago. The story I got was it was running when the guy parked it then it sat for five years until it was sold 9/18. I bought it in 2/19 and it wasn’t running supposedly because of an electrical issue. It had many other issues including electrical!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1331678 Tue Oct 29 2019 01:46 AM
What kind of gauge are you running and where is the line tapped into? I am with the others, try another gauge just to double check. Also, any chance you have an oil filter mounted? If so, what kind?
Mike
Phak1 #1331683 Tue Oct 29 2019 01:54 AM
Stupid question! If it’s a 1952 235, isn’t that still running babbit bar rings? If so, isn’t 15 psi about normal? My 216 normally sits between 10-15 psi.
Please educate me here as I don’t know much about the 235. Didn’t they change to full pressure around 1955.2?
Chris
Phak1 #1331686 Tue Oct 29 2019 02:01 AM
That is a bit strange because those numbers are about perfect for the low pressure version.
1951 1 Ton Completed
Phak1 #1331688 Tue Oct 29 2019 02:05 AM
ace skiver
Yes, Chris,
The 1935 engines were babbitted bearings - and, the low pressure oil system, both as you describe.
The original poster/post says at the end of the first post: “ At idle it drops to almost 0.”
That is not good for the engine’s bearings.
Tim
Moderated by  Woogeroo
