The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (Achipmunk, bluesman, bwilliams, Donf, DIY.MechanicMike, FinnBolt), 303 guests, and 1 spider.
Forums48
Topics117,184
Posts936,416
Members42,803
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 6 1 2 3 4 5 6
‘59 235 Low Oil Pressure #1331649 Mon Oct 28 2019 11:49 PM
Phak1 Offline OP
Jack of all Trades, Master of None
I know that these old engines are notorious for being able to run with low oil pressure but my question is how low is too low. I’ve finally had a chance to put a few miles on my ‘52 Chevy with a 235 installed. It pegs the needle on the 30 lb. gauge when I first start it but falls to 15 lbs. when it warms up (180 degrees) and running at 35-40 MPH. At idle it drops to almost 0. There is no valve clatter from the hydraulic lifters and no other unusual noises.
I’m running 10w-30 Valvoline.
This seem unusually low to me. This engine was rebuilt in 2013 and then sat for 5 years before I got it.
Your thoughts!
Phil
1952 Chevrolet 3104
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331657 Tue Oct 29 2019 12:43 AM
Builder Offline
How much oil does it burn? Try 10w40.
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331659 Tue Oct 29 2019 12:50 AM
Phak1 Offline OP
I haven’t driven it enough miles to tell if it is using oil. I don’t believe that it is burning oil because it doesn’t smoke and was rebuilt by a PO in a reputable shop. It came with the paperwork to prove it.
Phil
1952 Chevrolet 3104
12v w/ Alternator
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331666 Tue Oct 29 2019 01:16 AM
glenns towing Offline
possible inaccurate gauge. Id put 15w40 or 20w50 in it. See what gauge does then. Could try a different gauge also. Was the engine broken in or ever ran prior to you getting it?
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331667 Tue Oct 29 2019 01:17 AM
tclederman Online
Boltergeist
Heck, I’d try 20W50 oil - it is readily available and costs $20 (Walmart).
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331677 Tue Oct 29 2019 01:43 AM
Phak1 Offline OP
I don’t know if it was properly broken in because I didn’t buy it from the owner who had it rebuilt. That was two owners ago. The story I got was it was running when the guy parked it then it sat for five years until it was sold 9/18. I bought it in 2/19 and it wasn’t running supposedly because of an electrical issue. It had many other issues including electrical!
Phil
1952 Chevrolet 3104
12v w/ Alternator
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331678 Tue Oct 29 2019 01:46 AM
Dragsix Offline
What kind of gauge are you running and where is the line tapped into? I am with the others, try another gauge just to double check. Also, any chance you have an oil filter mounted? If so, what kind?
Mike
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331683 Tue Oct 29 2019 01:54 AM
ndkid275 Offline
Stupid question! If it’s a 1952 235, isn’t that still running babbit bar rings? If so, isn’t 15 psi about normal? My 216 normally sits between 10-15 psi.
Please educate me here as I don’t know much about the 235. Didn’t they change to full pressure around 1955.2?
Chris
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331686 Tue Oct 29 2019 02:01 AM
truckernix Offline
That is a bit strange because those numbers are about perfect for the low pressure version.
1951 1 Ton Completed
Re: ‘59 235 Low Oil Pressure [Re: Phak1] #1331688 Tue Oct 29 2019 02:05 AM
tclederman Online
Boltergeist
Yes, Chris,
The 1935 engines were babbitted bearings - and, the low pressure oil system, both as you describe.
The original poster/post says at the end of the first post: “ At idle it drops to almost 0.”
That is not good for the engine’s bearings.
Tim
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
