The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Hotrod Lincoln, dirtball, klhansen, BlueChipper, 2 invisible), 172 guests, and 2 robots.
Forums50
Topics120,985
Posts969,894
Members43,811
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Noisy Drivetrain
#1331651 Tue Oct 29 2019 12:08 AM
Phak1 Offline OP
AD Addict
I finally had a chance to put some miles on my ‘52 Chevy 3100 with a 235, the original 3 speed transmission and the original 4:11 torque tube rear. I would expect the transmission to be whiney in first and even second but quiet down in third. It is so noisy while driving @ 35-45 MPH, that it would be hard to carry on a conversation without talking loud. When I push the clutch in it quiets down. I won’t dare go any faster.
The transmission shifts fine. One other clue may be that the torque tube is leaking at the transmission.
Your thoughts?
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Noisy Drivetrain
Phak1 #1331676 Tue Oct 29 2019 01:43 AM
Could be the rear end as well. I wouldn't rule it out.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Phak1 #1331685 Tue Oct 29 2019 01:57 AM
There shouldn't be transmission fluid anywhere near that trans. It should be gear lube. Which is it?
Phak1 #1331697 Tue Oct 29 2019 02:28 AM
Phak1 Offline OP
AD Addict
Gear lube is leaking at the connection between the torque tube and the transmission.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1331699 Tue Oct 29 2019 02:47 AM
Ok great. But unless its draining as fast as your filling, you should be able to fill, drive and notice a difference if its a low fluid level causing the noise. If noise is still present, then damage may be done. And parts are required to quiet this beast. What I would do at that point is get it up in the air, have someone run it through the gears while you are under it with a mechanics stethoscope and start figuring from there. At least you be able to pin down the exact area of the culprit.
Phak1 #1331704 Tue Oct 29 2019 03:16 AM
Phak1 Offline OP
AD Addict
I topped it off before I started driving and it’s not pouring out, more of a weep. If I let it sit for week I’ll have a spot on the garage floor about 2” around. I’ve put less that a hundred miles on her since first started driving her.
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1331708 Tue Oct 29 2019 03:42 AM
Driving along a quiet street or alley with a wall on one side allows one to hear many noises. Some noise with a higher frequency than driveshaft could be countershaft. Pinion bearings usually will whine upon accel. coast. Throw out bearing could have noise changed by clutch application. Trans. bearings, driveshaft, pinion bearings would have higher frequency than rear axle bearings.
Ed
Phak1 #1332930 Thu Nov 07 2019 11:22 PM
Phak1 Offline OP
AD Addict
Well, humbled again, Glenns Towing was right. The issue was there wasn’t enough gear oil in the transmission. When I checked the oil prior to her first run, I stuck my pinky in and didn’t feel any. I added some gear oil and checked and thought I felt oil. This time I filled until it ran out. Messy but effective. A lesson learned. Its not total silent but I was able to get her up to 50 MPH and felt somewhat comfortable with running at that speed. Before that, 40 was stretching it.
Thanks all for you suggestions!
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1332954 Fri Nov 08 2019 03:51 AM
Glad to help. Keep on trucking. thumbs_up
Moderated by  SWEET
