The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (51sub, Donsz, D B Cooper, 3B, Frank50, Devilsix, 1 invisible), 129 guests, and 3 robots.
Forums50
Topics120,453
Posts965,458
Members43,679
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Adjusting the float on Rochester B
#1331342 Sat Oct 26 2019 11:47 PM
Need a bit of help adjusting the float on my Rochester B carb. I’m doing a rebuild and it says that the float level should be 1 9/32” and the float drop should be 1 3/4”. The float drop measures perfectly at 1 3/4”, but the float level measures 1 14/32”. I’m 5/32” too high and the adjustment pad is practically flat with no more room to adjust unless I push it past level. Should I do that to get it to 1 9/32”?
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
Re: Adjusting the float on Rochester B
Spotbiltxo #1331350 Sun Oct 27 2019 12:23 AM
HUH??????
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Spotbiltxo #1331354 Sun Oct 27 2019 12:37 AM
The position of the tab looks pretty normal to me. A very small change makes quite a difference out on the arms where the floats are located.
1951 1 Ton Completed
Spotbiltxo #1331359 Sun Oct 27 2019 01:31 AM
If it hasn't been straightened I will go with a taller setting (like 1 3/8 or so) so that the fuel level in the bowl will stay lower. This (a) makes it run a bit leaner and (b) keeps fuel from sloshing up where it will seep/weep/leak at that gasket line. You're at 1 7/16 and this is a little too tall. Fuel will cutoff a bit too soon. Just push the tab down a bit and check. This all got out of whack when the needle and seat changed. The old needle/seat let the float sit closer to the air horn when fuel cutoff occurred (meaning your fuel level would have been higher in there). Good luck.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Spotbiltxo #1331453 Sun Oct 27 2019 11:31 PM
Got the carb all back together and installed on the motor. Truck started on the first try, but then ran at full throttle! Stomped on the accelerator and nothing happened. Pulled the throttle and nothing changed. I shut it down and checked everything....... accelerator return spring still attached and working well. The throttle cable was correctly installed and not bound. Choke cable installed correctly and working properly. Accelerator pump working up and down nicely and not stuck or bound. Tried it again and the same thing happened. What is causing it to run wide open like this?
Chuck
1941 Chevy coupe
Spotbiltxo #1331461 Mon Oct 28 2019 12:37 AM
Need to pull the air cleaner, look down the throat and see where the butterfly is. Should be closed, sounds like it's not...by a lot. Time to adjust the throttle/accelerator cables.
Although you did state both cables are adjusted properly, can't imagine it going to wot without the throttle plate being out of position.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
Spotbiltxo #1331465 Mon Oct 28 2019 12:43 AM
Check the pivot on the linkage bell crank didn't flip over to the other side
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Spotbiltxo #1331540 Mon Oct 28 2019 12:52 PM
Thanks Ron and sstock. I’ll look down the throat and note the position of the butterfly. I’m sure that it’s wide open. Sstock, what is the linkage bell crank? Is it the long arm on the side with the coiled spring on it? That was a bit confusing when I put it back together.
Chuck
1941 Chevy coupe
Spotbiltxo #1331560 Mon Oct 28 2019 02:24 PM
Bell crank is the pivot assembly that bolts to the block, its function is to change direction 90 degrees from the foot pedal rod to the throttle arm.
1953 Chevrolet 3100
1964 GMC 1000
Spotbiltxo #1331576 Mon Oct 28 2019 03:56 PM
Okay, that part is working fine. No problem with wear or restriction.
Chuck
1941 Chevy coupe
Page 1 of 3 1 2 3
Moderated by  Woogeroo
