The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (1929chevydave, Justhorsenround, Tiny, Hambone, tclederman, SWEET), 88 guests, and 3 robots.
Forums50
Topics119,467
Posts956,550
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Specialty Tool: Update!
#1331435 Sun Oct 27 2019 09:40 PM
Tiny Online OP
Is there a specialty tool for loosening/tightening the clamp screw on the distributor. I don't have a problem with the '38 but the '53 is harder for me to access. I can get a screwdriver on the screw but can't turn it due to my arthritic hands. I used a slot head screwdriver bit with my 1/4" ratchet but had a heck of a time keeping the bit in the slot of the screw. What would work perfect would be a tool that looks like a 1/4" deep socket that slips over the head of the screw, has a recessed blade to fit in the screw slot and fits on the 1/4" ratchet. Is there something like that already in existence or do I have to invent one? grin
Re: Specialty Tool
Tiny #1331439 Sun Oct 27 2019 10:03 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Available but not sure if in the right size for a dist clamp screw.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Re: Specialty Tool
Tiny #1331456 Mon Oct 28 2019 12:05 AM
Tiny Online OP
What is it called so I know what to look for?
Re: Specialty Tool
Tiny #1331458 Mon Oct 28 2019 12:16 AM
Sorry Tiny, I can’t remember. If it pops back in I’ll let you know.
Re: Specialty Tool
Tiny #1331462 Mon Oct 28 2019 12:37 AM
You're probably looking for a screwdriver with a sliding screw starter that goes around the screw head. Not sure there's anything like similar that will fit on a ratchet wrench, though. You may have to adapt something to work for you since you have trouble with screwdrivers.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Specialty Tool
Tiny #1331464 Mon Oct 28 2019 12:42 AM
Jack of all Trades, Master of None
They make a extension for the bit that you are using, that has a sleeve that slides over the outside of the screw so it helps from the bit slipping off. I have a few that came in the sets when they first come out twenty or so years ago. You can then use a 1/4” drive socket ratchet like your using. If the socket falls off which is likely, tape the socket on to the extension.
Wally World sell one one on there website but not in the stores.
https://www.walmart.com/ip/Morris-P...r-
Extension-Screwdriver-Guide/20517525
Amazon also sells a Dewalt version that I’m sure you could find in your local hardware store.
https://www.amazon.com/dp/B0000225P8/ref=psdc_8107039011_t1_B000HNFKHS
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Specialty Tool
Tiny #1331468 Mon Oct 28 2019 12:55 AM
Good catch Phil
I didn't remember I even have one of those Dewalt ones. I came with a bit set that I got with a 1/4 hex impact driver.
Should be exactly what Tiny needs. Any hex shank bit should fit in it.
Re: Specialty Tool
Tiny #1331532 Mon Oct 28 2019 11:52 AM
Tiny Online OP
Thanks guys. I'll see what I can find.
Re: Specialty Tool
Tiny #1331596 Mon Oct 28 2019 06:07 PM
Can you convert the screw to a Phillips, clutch, square, hex, Allen socket or Allen button head? Anyone of those would hold a bit driver better than a slotted version.
Re: Specialty Tool
Tiny #1331665 Tue Oct 29 2019 01:08 AM
I swapped in an Allen head bolt so that I can use one of those Allen wrenches with the ball end on them. Man, is that nice!
Page 1 of 2 1 2
Moderated by  48bigtrucks, MNSmith
