The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (Boilermaker82, John Dlugos, Irv, Ott3r, aircav662, JosN), 445 guests, and 3 spiders.
Forums48
Topics117,300
Posts937,899
Members42,893
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 4 1 2 3 4
Re: My '53 9700 is home now [Re: Alex Arrow] #1331339 Sat Oct 26 2019 11:06 PM
EdPruss Offline
Bud wheels have tapered nuts and seats in the wheel. Motor rim and wheel have nuts with captive washers, nothing tapered.
Ed
Re: My '53 9700 is home now [Re: Alex Arrow] #1331358 Sun Oct 27 2019 01:31 AM
Alex Arrow Offline OP
Tried looking at at the engine again, but didn't see anything. Could it be hiding behind grease and dirt? Attached a photo.
The glove box tag, would it have been a sticker/decal type of tag? If so, it has since pealed off.
Alexander's Automotive Assortment
  • 1953 GMC 9700 (9783 HD)
  • 1989 GMC Vandura 1500
  • 1991 GMC S10 Jimmy 4x4
  • 1978 Plymouth Arrow
Re: My '53 9700 is home now [Re: Alex Arrow] #1331367 Sun Oct 27 2019 02:46 AM
EdPruss Offline
On machined pad behind distributor.
Ed
Re: My '53 9700 is home now [Re: Alex Arrow] #1331436 Sun Oct 27 2019 09:58 PM
spanky Offline
The glove box tag would have been attached by two small phillips screws.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Re: My '53 9700 is home now [Re: Alex Arrow] #1331633 Mon Oct 28 2019 10:11 PM
ExPress: Nut and washer.
Attached a photo of what I found by the distributor.
Spanky: Two holes by the corner(as seen in photo) but no tag.
All I got is the tags on the door frame. Attached a photo of it.
I found explanations of the truck serial, but what about the engine code?
Re: My '53 9700 is home now [Re: Alex Arrow] #1331720 Tue Oct 29 2019 10:55 AM
spanky Offline
Looks to be a 248 engine.
Spanky Hardy
1950 GMC 250 1-Ton
Re: My '53 9700 is home now [Re: Alex Arrow] #1331744 Tue Oct 29 2019 02:20 PM
3B Offline
Hy Alex Arrow, In my experience Canadian GMC engines which have serial numbers that begin with the letter "G" as on the serial number plate picture you posted are 248 engines. I believe the fact that your engine only has the numbers 248 indicates that the engine was replaced at some point in the trucks life, hope that helps.
Re: My '53 9700 is home now [Re: Alex Arrow] #1331855 Wed Oct 30 2019 02:12 AM
Tanner Offline
Moderated
Nice looking truck!
My grandfather had a truck like that - it was sold in the early Eighties. I'd like to find another one for use on our small farm.
Bryan
Re: My '53 9700 is home now [Re: Alex Arrow] #1331866 Wed Oct 30 2019 03:18 AM
2ManyTrucks Offline
you probably have a Chevy engine, Canadian GMCs in those years come with Chevy engines when new and the truck frame would need to be modified to accept a GMC engine if someone had managed to fine one to put in there
give us a better view of the overall engine or the block casting number, but from what i see in the photos you have a replacement 235 with non factory stamped numbers (number physical size is too small)
-stan
Re: My '53 9700 is home now [Re: Alex Arrow] #1331904 Wed Oct 30 2019 02:09 PM
EdPruss Offline
The stamped 248 most likely denotes a replacement GMC block as mentioned above, that never had the additional numbers stamped from the original engine, Chevy never had a 248 engine.
Ed
Page 2 of 4 1 2 3 4
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
