The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
27 registered members (47fivewindow, Bill Trotter, Bill Marlow, baldeagle, blanch53, Achipmunk, 3 invisible), 499 guests, and 3 spiders.
Forums48
Topics117,120
Posts935,833
Members42,785
Most Online1,229
Jan 21st, 2020
Image Posting Policy
270 into a 1.5 ton #1331302 Sat Oct 26 2019 06:23 PM
I
Iain Offline OP
Moderated
Hi there stovebolters, I'm hoping you can help me out.
I have a 42 one and a half ton truck with a cracked block, I also have a 55 gmc 270 engine, what I would like to ask if any of you gents have done this swap before ?
I've already checked and the bellhousing and clutch fit right on, and I don't mind a little bit of fabrication regards the mounts or the cab floor as I know the 270 is a little bit longer.
I await your answers from your own experiences good or bad with bated breath.
Best regards
iain
Re: 270 into a 1.5 ton [Re: Iain] #1331315 Sat Oct 26 2019 08:24 PM
tclederman Online
Boltergeist
Into a 1942 1.5 ton Chevrolet or GMC truck?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 270 into a 1.5 ton [Re: Iain] #1331325 Sat Oct 26 2019 09:22 PM
Wayne67vert Offline
I put that same motor in my '38 Chevy 1 ton. The rear mounts required some wedges to make them work. The front mount required a new hole drilled into the cross member. The radiator was moved to the front of the radiator cowl making room for the fan.
Wayne
1938 1-Ton Farm Truck
Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. malmwayne@hotmail.com
Re: 270 into a 1.5 ton [Re: Iain] #1331338 Sat Oct 26 2019 11:02 PM
EdPruss Offline
Sounds like Wayne has it all worked out.
Ed
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
