The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (78buckshot, 52_Ton, 51sub, baldeagle, Coltrain, 1 invisible), 257 guests, and 4 robots.
Forums47
Topics117,644
Posts941,070
Members43,017
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Odometer Disassembly
#1330756 Tue Oct 22 2019 11:13 AM
JakeM Offline OP
How does the odometer break down (1950 GMC). Do the brass washers/retainers pull off the shaft on the ends (attached photo with red arrows)? I wanted to find out the right way before I took a pair of channel locks to it. I’m familiar with the speedo rebuild tech tip, it doesn’t tell how to actually disassemble the odometer to get the wheels off the shaft. Any help would be appreciated.
Re: Odometer Disassembly
JakeM #1330986 Thu Oct 24 2019 02:07 AM
JakeM Offline OP
Turns out I didn’t need to disassemble it to roll it back to zero. It can be done by playing around with the wheels for 5 mins or so to figure it out, not to difficult.
JakeM #1331138 Fri Oct 25 2019 05:11 AM
Is it legal to roll back to 0?
Britcon #1331139 Fri Oct 25 2019 06:40 AM
Depends. If you do, you'd likely have to notify your DMV to put some sort of notation on your title. It matters when you transfer the title. Falsely representing the mileage of a vehicle for sale is illegal in most, if not all, jurisdictions.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
