The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (53 green 1- ton, Phak1, porsche, JW51, TPR57C, Mike Burns), 98 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,915
Members46,061
Most Online1,229
Jan 21st, 2020
#1331117 Fri Oct 25 2019 01:37 AM
Ford351 Offline OP
Hi all my first post and my first Stovebolt 48 gmc firetruck with a 270 I know this from the only number on the boss is 270 and by measuring the bore. Tuck has been sitting 20 + Years couldn’t get it to start After a compression test I found low compression to be the culprit. #2&4 has 0 the rest had 30. Removed the head found the seats to be pounded and rusted out. Sending head in for a complete rebuild. Upon inspection of the engine #4 cylinder had a small patch of rust. A ball hone was used on the top 3/4 of the cylinder and it came out pretty good. Now the only other issue is I have 3 lifters with some galling on the cam face Dose any body know where I can get three new lifters? Thanks and I can’t wait to hear from you guys
Ford351 #1331126 Fri Oct 25 2019 03:11 AM
If you find ( 3 ) new lifters .
Do you think that will fix the damaged cam lobes ?
Sounds to me like you need to get the camshaft reground
and the lifters refaced if that's even possible .
Usually galling goes deeper than refacing can fix .
You can bet the cam lobes are damaged if the face of the lifters are galled .
https://egge.com/info/lifter-resurfacing/
https://www.triumphexp.com/forum/sp...e-lifters-without-replacing-cam.1253035/
George
'54 3600
1954 3600
Ford351 #1331194 Fri Oct 25 2019 06:59 PM
There is a new GMC camshaft on Ebay for $270.00. The same "milk can" solid lifters that work on 216's and 235's also fit GMC inline six engines of all sizes. Those are available on Ebay also. If any of your lifters are junk, so is the cam.
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
Ford351 #1331212 Fri Oct 25 2019 09:30 PM
Delta cams in the Seattle area does cams and lifters, too.
Ed
Ford351 #1331224 Fri Oct 25 2019 11:43 PM
They do nice work (Delta) and can recondition the lifters if I they are in ok condition. Ask for a mild 3/4 cam grind. Might as well inspect bearings.
Ford351 #1331287 Sat Oct 26 2019 02:10 PM
I just read a few very negative posts about Delta cams
on the internet . They seem to have a problem of losing
camshafts on customers .
I'd try , Oregon Cams
http://www.oregoncamshaft.com/
You'll need a full set of ( 12 ) " Chilled Iron Base " Lifters for
your FORGED STEEL CAMSHAFT .
No other look a likes will be metal to metal compatible .
Stay away from any recently made lifters or made in china junk .
On ebay , there's a full set of aftermarket lifters made way back when .
They are made in the USA by a very good quality aftermarket company ' Wohlert's ' .
They are old time aftermarket lifter replacements for the original GMC
" Chilled Iron Based "....Lifters......GMC # 2194006 .
Go to ebay & type in the search box..........2194006
A set of Wohlert's lifters will show up @ $150.00 for the set of ( 12 ) .
PIC
https://i.postimg.cc/cHy68xYc/GMC-Wohlert-s-Lifters-replaces-GMC-2194006.jpg
Then you can send your cam out to be reground .
If you are serious about getting your engine running again . I would not pass up the chance to get
these old time scarce lifters .
These " Chilled Iron Base " lifters CANNOT be used with any cast camshaft .
George
'54 3600
1954 3600
Ford351 #1331288 Sat Oct 26 2019 02:28 PM
I have been using them for close to forty years, they are about 10 miles from me. I just had them ground a 261 cam for me and surface all my solid lifters, cost me $150. Be very careful on how you read the nay sayers on the internet. These guys have been in business doing good work all across america for at least 1/2 century. They know their stuff and I have 100% confidence in them. About 5 years ago, they moved their operation down the street 4 blocks. They had a lot to move and many cores and machines, sure I bet a few things got misplaced. If you are that worried, send your stuff to me and I'll personally take care of it. I live in the pacific northwest and never heard of Oregon Cams.
Steve
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
