The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (bobhawkins, darthintel, BC59, Dennis67, 3800GUY, 58n63), 198 guests, and 3 robots.
Forums50
Topics119,952
Posts960,642
Members43,521
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
235
#1330281 Fri Oct 18 2019 01:15 AM
On Page 9 of Deve Krehbiel's book on how to rebuild the inline-6 engine, he states "...the desirable years are 1954-1962 with the 1958-1962 being the most desirable because of all the lessons learned by Chevrolet through the years".
So, what is the major difference between say a 1955 235 and a 1960?
Re: 235
WarEagle1 #1330284 Fri Oct 18 2019 01:43 AM
There were several oiling system changes during that time period.
Check out this article:
http://chev235guy.blogspot.com/2015/04/235-rocker-oiling-evolution.html
'59 Chevy Suburban, NAPCO
Re: 235
WarEagle1 #1330286 Fri Oct 18 2019 02:15 AM
Oil system changes as noted above, slightly higher compression ratio if the shop manual is to be believed. Some other things, for example in 55 gm was still using a rope rear main seal. In 60 those motors were using the much improved neoprene seal (that actually began in 56). Also in 55, all stick motors used a block that was machined for solid lifters only. This was trucks and cars. For the cars with automatic transmissions, they received a different block, one that was machined for hydraulic lifters. That distinction ended for the 1956 models, although I can’t say for certain whether the 56 and up trucks used a solid lifter only motor (they may have) only because I have never had one in my hands. Maybe one or the other guys can chime in on that. But never shy away from a 55-58 motor. They are great runners just like the 59 and up motors
Mike
Re: 235
WarEagle1 #1330339 Fri Oct 18 2019 03:21 PM
I bought Deve's book too and found it to be a valuable resource. Though I do not agree with all of his advice. I do agree with his assessment that the late 235's are the better ones. Though there are challenges to putting one in a 55-1st or older truck, mostly because of the water pump. http://chev235guy.blogspot.com/search/label/Water%20Pump%20Relocation%20Adapter
Professional Novice
Re: 235
WarEagle1 #1330343 Fri Oct 18 2019 04:33 PM
ace skiver
No truck 235/261 engine had hydraulic lifters (except, maybe, in/on an early 60’s truck that had a Powerglide transmission).
The higher compression “848” head (1956 and later engines) provided improved/higher performance compared to earlier high-pressure-235 heads.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: 235
WarEagle1 #1330350 Fri Oct 18 2019 05:47 PM
Weren’t hydraulic lifter motors found in Canadian made cars? Correct me if I am wrong.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Re: 235
WarEagle1 #1330360 Fri Oct 18 2019 06:24 PM
Believe all cars had hydraulic lifters after 55
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Re: 235
WarEagle1 #1330383 Fri Oct 18 2019 08:37 PM
Canadian Pontiacs used essentially the 55-58 bypass 261 block with an 848 head (with steam holes) and those blocks were drilled for hydraulics so you could use either hydraulic or solid lifters. Yes, no truck used hydraulic lifters. The question I don't have an answer to is notwithstanding that truck blocks came with solid lifters, were they drilled for hydraulics. In other words, did GM do away with the separate block distinction like they did in the automobile line or did they continue to use blocks in the truck line that were solid lifter only and if they did for how long. I just dont know the answer to that.
Mike
Re: 235
WarEagle1 #1330395 Fri Oct 18 2019 09:16 PM
Starting in 1958 all 235's were drilled for hydraulic lifters whether used or not.
This was because of the new rocker oiling set up that flowed oil around each lifter and up a cast in galley in the center of the block.
261's seem to have a different time line for this change, which I have not confirmed.
My Blog
Re: 235
WarEagle1 #1330398 Fri Oct 18 2019 09:46 PM
Yes the 261s didn't follow suit as the 235s, but I dont have the exact knowledge of the specs,. Im sure the experts will chime in.... Hopefully.. dance
Page 1 of 2 1 2
Moderated by  Woogeroo
