The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (DaveV, Bwienke, Bill Marlow, DES57, 1955first6500, 1 invisible), 83 guests, and 3 robots.
Forums60
Topics127,472
Posts1,031,732
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 31 1 2 3 4 30 31
Re: 1952’ Chevrolet 3100 Project
sstock #1330361 Fri Oct 18 2019 06:24 PM
Originally Posted by sstock
The biggest being the fact that the clutch disc was installed backwards and the hardened springs on the disc ground down the flywheel bolt heads, making it a complete whore to tear apart.
Steve, the amazing part of that is that it apparently was driven that way. The first time the clutch pedal was depressed it probably let out a hellacious racket. That and that it probably didn't shift for crap.
I find stuff on my truck that makes me scratch my head, thinking "Why would anyone do that??", but nothing that crazy.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Phak1 #1330365 Fri Oct 18 2019 06:33 PM
Phak1 Offline OP
AD Addict
sstock, Stay tuned! I have six months of updates before I catch up to present day, and restorations by PO’s get worse. Thanks for following and for your sympathy.
Phil
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Phak1 #1330415 Sat Oct 19 2019 12:41 AM
Phak1 Offline OP
AD Addict
2/17/19:
* I removed both taillights, cleaned, reinstalled and spliced new wire where required.
* I traced out the wires and spliced in the right side head light.
* I removed both parking lights and cleaned. The housings on both lights have been modified for signal lights by drilling a 5/8” hole and installing a push to mount socket. The bulb is a single filament dash light bulb and is way to small to effectively work as a signal light. There are several solutions for this issue. One is to buy new reproduction (repop) parking lights with a dual filament bulb for about $60. I question the quality (made in China) and would prefer to either repair or replace the existing housing with unmodified OEM. New sockets are available to replace the single filament with a dual filament so the signals can be hooked up.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330429 Sat Oct 19 2019 02:41 AM
Phak1 Offline OP
AD Addict
2/23/19: I disconnected the gauge cluster, headlight switch and the speaker trim from the dash to gain access to the wiring. The main 12v splice was a soldered joint made the original fabric wire. I looked over the wiring diagram and the configuration under the dash and determined how to eliminate the splice by utilizing the extra terminals on the headlight switch. I first:
* Connected the alternator to the 12v feed on the Head light switch using 10 gauge wire.
* I then made a jumper from 10 gauge wire connecting the the 12v feed to the negative side of the amp gauge.
* I then connected the positive side of the amp gauge to the starter with another 10 gauge wire to complete the circuit.
* To supply the current to the ignition switch I made a 14 gauge wire connecting the negative side of the amp gauge to the ignition switch.
These changes eliminated the rest of the old fabric insulated wire except the gauge lights on the dash.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330448 Sat Oct 19 2019 01:15 PM
Phak1 Offline OP
AD Addict
2/25/19:I installed the new starter switch and installed a new bypass wire to the coil. I re-wired the coil so the current from the key switch goes thru the resistor. Seems to work, I need to get her fired up to see. Allot more work to do before I get to that point.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330458 Sat Oct 19 2019 03:25 PM
Phak1 Offline OP
AD Addict
2/20/19:After discovering the butchery that was performed to accommodate the longer water pump, I looked for possible solutions to remedy the issue and return the truck close to it’s original condition.
The water pump sticks out further then the 216 did so your unable to mount the radiator in it’s original position. It is also lower by about 3”, so the fan is not centered. Apparently, the owner during the 216 to 235 swap decided to move the radiator to the front of the radiator support to gain fan clearance. In order to accomplish this, the lower splash pan was cut and the hood latch panel in front of the radiator was cut and bent down to provide the required clearance.
The solution, I found in this forum. “Pre ‘68 Dave” sells a water pump relocation plate that utilizes the original water pump and the original fan from a 216. The harmonic balancer must be replaced with one from a 216, in addition to the alternator pulley and the fan belt to 5/8”. This will enable me to return the radiator back to it original position. At that point I will be able the fix or replace the modified splash pan and hood latch panel. This is definitely a future project, but in the meantime, I’d like to get her running.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330522 Sun Oct 20 2019 01:32 PM
Phak1 Offline OP
AD Addict
2/24/19:The gas gauge pegs to full when the ignition is turned on. To make a long story short, after spending the day troubleshooting, rewiring, checking grounds etc., I determined that the sending unit was bad. I ordered a new sending unit.
After taking out the sending unit trying to diagnose the gas gauge problem, I discovered that the inside of the tank is varnished from old gas and is rusting. I suspect that the whole fuel system needs to cleaned out.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330523 Sun Oct 20 2019 01:37 PM
Phak1 Offline OP
AD Addict
2/25/19:I removed the shutoff valve and it was plugged with varnish. I cleaned it out and it appears to be good. I disconnected the gas line from the fuel pump and blew it out with air. It was really dirty and should be replaced. The tank was boiled out by a PO about 5 years ago but the bottom was still pretty dirty. I tried to clean out the tank with rags on a stick but I’ll need to remove it to clean it better.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330525 Sun Oct 20 2019 01:54 PM
Phak1 Offline OP
AD Addict
2/27/19:I removed the gas tank to clean it out a little better. I plugged the fuel line inlet, added about a pint of gas to slosh around, then emptied into a pan. I repeated the process a couple of dozen times until my arms were killing me and I got it to run fairly clear. After reinstallation of the tank I added an extra in line filter between the tank and the fuel line to address any left over debris in the tank. The amount of rust and debris that come out of the tank was unbelievable.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery
12v w/ Alternator
Phak1 #1330527 Sun Oct 20 2019 02:36 PM
Phak, good idea on the inline filter before the pump, dont use one of those little bitty ones, you will have issues immediately. I learned that lesson on my T bucket build years ago. A filter with a removable canister so you can clean it out like this one:
fuel filter The pump has to be able to draw through the filter under vacuum, some are built to be pressurized through them, definitely dont want one of those.
A rusty tank may mean all the anti corrosive coating is gone and it is just going to rust more, new tanks are just $150, you might rethink it later. Keep building, you are moving along.
Steve
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Moderated by  HandyAndy
