The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (55shaker, james1961, BC59, 2ManyTrucks, J Lucas, 1 invisible), 150 guests, and 3 robots.
Forums60
Topics123,939
Posts1,000,190
Members44,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Rear Barn Door Question
#1329729 Sun Oct 13 2019 02:04 PM
JakeM Offline OP
I'm having an issue with my rear barn doors on my 1950 Panel not staying latched. The latch assembly, catches, and everything involved with them works correctly (the doors close, latch, and unlatch), but with the slightest pressure I can pull the left side door open without using the handle. As long as the truck isn't moving, the doors stay closed. But when I start going down the road, even the slightest bump will cause the doors to pop open. I've replaced and beefed up the "catch plates" on the top and bottom of the door of the left side where the door "hooks" catch so there is full engagement, but like I said, just a slight pull (without using release handle) and the door opens. Is there a part or adjustment I could be missing inside the door, that keeps the "hooks" on the top and bottom of the left door from moving when the handle is not being pulled?
Re: Rear Barn Door Question
JakeM #1329733 Sun Oct 13 2019 02:09 PM
This is a lame guess/question : are the hinge pins tight (no door “wobble” due to wear)?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
JakeM #1329736 Sun Oct 13 2019 02:30 PM
JakeM Offline OP
No, those are good. No wobble. It just seems that the two “hooks” On the top and bottom of the driver side door, shouldn’t be able to be moved so easily without the handle being pulled. It’s kind of hard to describe, as I sit here and read over what I have typed, but for example I just take my index finger on the top “hook”, I can push it up and down really easily, Meaning it moves in and out of the door. I’ve tried every adjustment I can think of, including the long rods that connect the pull handle to the latch hooks on the top and bottom of the doors. It would almost seem to me that there would be some kind of “stop” near the pull handle, or near the hooks at the top of the door that would prevent them from being “pulled in,” without pulling the release handle.
JakeM #1329752 Sun Oct 13 2019 05:38 PM
Are the small springs still intact and have good tension strength on the latches ?
barn door latch
Tim
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
JakeM #1329754 Sun Oct 13 2019 06:05 PM
JakeM Offline OP
The springs are there. The hooks retract into the door when the Handle is pulled, then “spring” back out when the handle is released. I’ll double check how worn the tension is, maybe that is contributing to the issue.
JakeM #1329758 Sun Oct 13 2019 06:26 PM
I would also check the adjustments of the adjustable rods to each latch.
Tim
JakeM #1329786 Sun Oct 13 2019 10:34 PM
....does yours have the spring on the "middle handle" itself that you pull back to open that door.....like on my 52.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
JakeM #1329810 Mon Oct 14 2019 12:59 AM
Alvin , is this the spring you speak of on the left barn door?
door latch spring
door latch handle
Tim
JakeM #1329860 Mon Oct 14 2019 01:25 PM
JakeM Offline OP
Everything seems to be correct based on diagrams I've seen and suggestions you've all made. I have the springs on the top and bottom of the door, and the one that is wrapped around the shaft of the handle that is in the middle of the door. I appreciate all the suggestions/help with this. I think I'll just have to fabricate something to prevent those hooks from retracting when the door is pulled outward. Or I could just keep the ratchet strap in there that is keeping tension on the door from the inside....
JakeM #1329871 Mon Oct 14 2019 03:28 PM
Yes Tim, thats the one.
Jakem, I had some what the same problem, not exactly but..... i ended up welding, building up, the "catch" that is fastened to the top and bottom of the body, and found the springs on the latch that goes in the door catches were very week. I lucked out and got a box of extra parts from a fellow bolter and after some tweaking and using parts better than mine the problem went away..
Good luck, and let us know what it took when you get it resolved.....Knowledge is our best resource!
Page 1 of 2 1 2
