The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (DennisM, Johnny N, 66flea, Hog Wild, frogfarmer, Harold41), 131 guests, and 3 robots.
Forums50
Topics119,460
Posts956,464
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
LT1 and 4L60E going in a 1950 3100
#1329726 Sun Oct 13 2019 01:21 PM
Anyone else out there doing the above combo? I plan to install an aftermarket Mustang II on my truck. What issues if any did you run into?
Re: LT1 and 4L60E going in a 1950 3100
Rocket man #1334160 Mon Nov 18 2019 02:28 AM
I’m getting ready to build the frame on my 51 and it has a mustang II front end. I’m planning on using a 350 only because i have one lying around. Do you have pics i can see?
1951 GMC 3 window 100
1951 GMC 5 window 100
Rocket man #1334437 Wed Nov 20 2019 04:39 AM
You will need to address the center crossmember. It will likely be in the way of your transmission. Even if it isn't, you will have trouble if you ever need to pull the transmission later on.
I cut the middle of of mine, welded drop plates to the stub ends of the remaining ends which are riveted to the frame and welded plates to the ends of the removed center section, and drill holes for bolts so that I could bolt the center back on leaving it about 2 inches lower than it was.
Moderated by  Woogeroo
