The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 102 guests, and 3 robots.
Forums50
Topics120,522
Posts966,059
Members43,692
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Question for you guys that drive dual wheel trucks
#1329598 Sat Oct 12 2019 11:26 AM
I want to compare some driving techniques with you all...I have a situation where my dual wheeled trucks rear tires will slide on wet leaves when descending a steep hill. Obviously if both rear wheels on the axle slide the truck can go into an uncontrolled slide. No brakes are applied, low gear manual transmission regular compression braking, in 2WD. The question is: what is your technique to regain vehicle control? I have my answer, but want to hear others thoughts.
Re: Question for you guys that drive dual wheel trucks
Paul_WNC #1329601 Sat Oct 12 2019 12:36 PM
Paul, can't say as that's ever been a problem with my dually ('95 Dodge). I've driven it about 300k and the only time I worry about the rear breaking traction is when going up or down a snow covered mountain pass, often with a 12,000 lb hunting trailer hooked on when driving in Colorado. We're heading out in 4 days and it's sometimes a white knuckle, religious experience. Not looking forward to the weather they're currently having out there.
My guess on why you're having issues is the front brakes. If the front's are a bit less than perfect I can see how the rears (when the truck isn't loaded) would lock first. Perhaps adjust the fronts up to the max so they'll do the majority of the braking?
I am interested in hearing your solution.
Best,
RonR
1970 340 Duster
1951 Farmall Super A
Paul_WNC #1329602 Sat Oct 12 2019 12:47 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
As with most any slide....get off the brakes. Start your way down in a lower gear.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Paul_WNC #1329621 Sat Oct 12 2019 04:06 PM
I made some edits (in red) above to clear up the original question.
Paul_WNC #1329631 Sat Oct 12 2019 05:41 PM
Even on an SRW pickup that's lightly loaded, the rear wheels may slide with just compression braking (fronts freewheeling). My solution is to disengage the clutch and use the brakes, but that's not an available solution for you guys that drive automatic tranny trucks. But applying the brakes lightly should work. If I have the hubs locked, I'll pull it into 4WD. But if you lock up the fronts, then you have no steering, which can induce some pucker factor. In that case, it's better to get off the brakes and try to steer thru it. That's the old saw "steer in the direction of the skid".
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Paul_WNC #1329632 Sat Oct 12 2019 05:43 PM
Just a thought. Might try shifting to neutral or depressing the clutch on a manual transmission. No I don't drive a dually. That is just my 1st thought.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos!
Paul_WNC #1329737 Sun Oct 13 2019 02:31 PM
I
I drove a water truck at a rock crusher with 4 wheel drive with dual rear wheels and when loaded going down a muddy slick hill I left it in gear and used light, steady pressure on the brake pedal to keep the speed down . It allowed the antilock braking system to maintain traction by making sure all four tires slow at the same rate when you apply the brakes.
Moderated by  Bouncer, Justhorsenround, Tiny
