The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (Hotrod Lincoln, 2 invisible), 179 guests, and 5 spiders.
Forums48
Topics117,378
Posts938,556
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 3 1 2 3
Re: Voltage drain needs investigation [Re: Lugnutz] #1329362 Wed Oct 09 2019 06:34 PM
Lugnutz Offline OP
So it seems that everyone is of the opinion that 1.03 mA is no big deal. I will try to figure out where it’s coming from none the less. As far as why the horn began to blow on its own, I suspect that it was something in the steering column after all. Now that the steering column has been removed from the truck, the horn does not blow.
I’m assuming that 10.5 V would be enough to trigger the relay if there was a problem.
Re: Voltage drain needs investigation [Re: Lugnutz] #1329365 Wed Oct 09 2019 07:59 PM
Lugnutz Offline OP
Laugh at me if you want, but here is what I think happened the day my horn started blowing all by itself.
1. Something in my steering column caused a ground connection to the brown wire that goes to the horn relay.
2. I unplugged the wire to the horn but the relay was still activated by the ground.
3. The still activated relay drained my battery.
4. Once the battery was dead, the relay disconnected internally.
5. Since removing the steering column from the truck, the ground to the horn relay has been eliminated.
6. I’ve discovered an incidental 1 mA drain on the battery that has nothing to do with the original horn problem.
7. I need a new battery. My battery must have been on its last leg because even after charging, it’s still not able to deliver 12V.
Re: Voltage drain needs investigation [Re: Lugnutz] #1329366 Wed Oct 09 2019 08:21 PM
klhansen Offline
Sounds plausible. Relays will often engage, and the load draws the voltage down, causing the relay to drop out, and the battery recovers allowing the relay to re-engage,causing the voltage to drop, etc. etc. That's the reason you get the "click-click-click" on a starter relay with a low battery.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Voltage drain needs investigation [Re: Lugnutz] #1329373 Wed Oct 09 2019 09:42 PM
bartamos Offline
Truck Whisperer
Not laughing at all. This is troubleshooting 101, DIY style. It's very easy to misdiagnose and chase your trail. I've done it many times and am trying to get smarter. Thanks for keeping us updated, This is how we all learn together. Many good ideas and suggestions on this post with you doing all the hard work. Hope the new battery and rebuilt/rewired column gives good results.
Tests you need to do in the future with new battery.
1. Test battery at rest. Test across the posts and get 12.6V or close. Battery good.
2. Test battery, motor running. Test across post, and then across post clamps, to get 14V or close. Alternator good.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: Voltage drain needs investigation [Re: Lugnutz] #1329394 Thu Oct 10 2019 12:28 AM
52Carl Offline
Good find Lugzy! I was getting ready to post that "I told you so," but I never made a post at all until this one smile
Re: Voltage drain needs investigation [Re: Lugnutz] #1329415 Thu Oct 10 2019 02:43 AM
Shakey61 Offline
Good job!
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
Re: Voltage drain needs investigation [Re: Lugnutz] #1330502 Sun Oct 20 2019 01:46 AM
Joe W Offline
My battery drains 2mA...as the alternator shows a resistance of 5.8k... Im not sure if that is standard...either way,..something else to investigate.
Re: Voltage drain needs investigation [Re: Lugnutz] #1330602 Mon Oct 21 2019 01:18 AM
Shakey61 Offline
A single garden-variety LED draws 20mA when lit. Unless your meter can read down to μA, 1 or 2 mA is a rounding error, and of no concern. My cigarette-lighter USB charger has a blue LED for backlighting, so there's 20mA even when nothing is plugged into it.
-Kevin
Page 3 of 3 1 2 3
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
