The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (farmallb), 219 guests, and 3 robots.
Forums50
Topics120,075
Posts961,667
Members43,548
Most Online1,229
Jan 21st, 2020
Image Posting Policy
master cylinder rebuild removal necessary?
#1329317 Wed Oct 09 2019 03:23 AM
morerog Offline OP
Is it necessary to remove a master cylinder in order to rebuild it?
There is only a very slow leak at the from of the MC, and otherwise has been working great.
Roger Schroeder
1951 Chevrolet 3600.
Re: master cylinder rebuild removal necessary?
morerog #1329333 Wed Oct 09 2019 11:39 AM
It’s not usually necessary to remove master or wheel cylinders to hone and rebuild them.
Sometimes better to leave them installed if removing might lead to more work than you’re prepared for.
Alternatively often easier to just remove them and work on things on the bench and get a better view.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
morerog #1329339 Wed Oct 09 2019 12:27 PM
Jack of all Trades, Master of None
Assuming we are talking about a below the floor master cylinder, I just removed mine in about 15 minutes on my 52’ 3100 to rebuild it. After cleaning and honing, I decided to replace it due to corrosion in the bore that I could not remove. I don’t think I would have seen the issue with the master cylinder installed. I also can’t fathom performing all the work involved in the rebuild lying on my back. In addition, the back of the master cylinder is only a few inches from the rear transmission crossmember so honing it would be near impossible.
I second Grigg’s suggestion to remove and work on the bench. Your back will thank you
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
morerog #1329423 Thu Oct 10 2019 03:24 AM
Fox Offline
The greatest teacher failure is.
Anyone know where a guy can get s dust cover rubber boot for the pushrod plunger? I have nalresdy replaced the interanls, but now can’t find the dust boot independently to complete the rebuild.
Sorry to hijack...😬
I vote remove it as well. Working on your feet is so nice; plus you don’t have dirt falling in your eyes (or your new cylinder!).
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Fox #1329425 Thu Oct 10 2019 05:32 AM
I try to work sitting down whenever possible. Even nicer than working on my feet. thumbs_up
I removed my MC after the cab was off so didn't have to worry about the dirt.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Fox #1329429 Thu Oct 10 2019 11:25 AM
Quote
You should find what you need on one of these sites.
TRY HERE
Ebay
Steele Rubber
Harold
Harold
morerog #1329431 Thu Oct 10 2019 11:54 AM
You can buy it at Classic Parts but shipping is $9.95 minimum. Do you need anything else?
https://www.classicparts.com/1947-72-Master-Cylinder-Boot-Manual-Brake/productinfo/71%2D285/
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
morerog #1329460 Thu Oct 10 2019 07:16 PM
General Purpose
Morerog: I have never even thought of doing it on the truck so don't know how hard it is. I've only done it on the bench.
could not do a good inspection, ream job, parts insert job or bleed job lying under the truck. It's the brakes you know.
Hijacker:
Most, but not all, of the parts at Steele are American made with American rubber. They will last way longer than all the other off shore pieces. Email them to see if this boot is made in USA. If not, the cheaper ones may be from the same source*. If made here, buy that one.
Steele used to be 100% American made parts. I guess they had to compete with some parts or not enough demand to build tooling. Anyway, they still make most at their factory.
* Their site says they buy some parts from outside vendors who buy from off shore.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Moderated by  SWEET
