The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (klhansen, TPR57C, TGP, 1 invisible), 183 guests, and 3 robots.
Forums50
Topics119,959
Posts960,710
Members43,525
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Carter YF 2100s cable bracket
#1328400 Tue Oct 01 2019 04:52 PM
Guns Offline OP
Moderated
Anyone out there have the double cable bracket (throttle and choke) for a Carter YF 2100s?
Mark kline
Re: Carter YF 2100s cable bracket
Guns #1328527 Wed Oct 02 2019 03:22 PM
These are devilish difficult to find. In the group of Rochester parts I offered for sale a month or two ago there is one of those 2 cable brackets for Rochester carbs. It might work or be able to be modified for the Carter, but I'm not interested in breaking the Rochester parts group up into parts. I'll see if I can bump that up to the top.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Guns #1328671 Thu Oct 03 2019 07:16 PM
Jon,
Does a YF 966S use the same bracket or different than 2100s ? I am looking for that bracket too.
Guns #1328689 Thu Oct 03 2019 11:24 PM
I have both a 2100S and a 966S and the brackets appear identical to me. In fact the carbs look pretty much identical. In this earlier thread Jon listed the internal differences. https://www.stovebolt.com/ubbthread...ew/1/questions-on-carter-yf.html#UNREAD. In that same thread a list of what carbs were used on what years is posted. That list was produced by Carbking and has been widely reproduced in many threads. Unfortunately it is in error regarding the 966S which lists it as an autochoke model. It lists a 967S as manual choke. The 966S is the manual choke model. I tried to sell my 966S carb and the potential buyers used that list to tell me I didn't have a correct carb.
Guns #1328704 Fri Oct 04 2019 01:35 AM
As far as I know the 966s and 2100s used the same bracket. I'm also pretty certain you could adapt the Rochester bracket to work. I'm traveling now but will be happy to check that when I return.
Jon
Guns #1328713 Fri Oct 04 2019 02:35 AM
I've used the Rochester bracket on both the 966s and 2100s. It works fine.
https://photos.app.goo.gl/2Nb5E8rDGQennfSm6
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
Guns #1328789 Fri Oct 04 2019 08:27 PM
Great Information MarkT
Thank you.
Hookalatch #1328866 Sat Oct 05 2019 11:59 AM
Carburetion specialist
Chuck - I checked and double checked the information when I made the list. And I should have triple checked wink
The corrected list is available on my website at: Chevrolet YF carburetors
I apologize for any problems the mistake may have caused.
Jon
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Moderated by  Woogeroo
