The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (klhansen, Devilsix, Eureka Jim, Mike B, aircommando462), 96 guests, and 3 robots.
Forums50
Topics120,460
Posts965,505
Members43,679
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: bleeding disk/drum brakes
rc356s #1326701 Wed Sep 18 2019 06:58 PM
Special brake pliers are made for this purpose, inexpensive. Or a piece of rod, bent for a handle, grind a groove very near the end, getting deeper as one goes around the rod.
Ed
rc356s #1326708 Wed Sep 18 2019 08:20 PM
ace skiver
As Ed suggested, brake spring pliers (and other brake tools) - make the job easier and quicker.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
rc356s #1326907 Fri Sep 20 2019 12:41 PM
The correct tool as shown in the manual, uses the lining surface to pull against. That tool can make grooves and marks in the lining.
With all the posts that I have seen with problems bleeding the modified split brake system, it makes me wonder if the system would provide any braking at all when one system fails. I haven't seen a post where someone actually experienced this. I know that the split systems as they came from the factory did indeed work.
1951 1 Ton Completed
rc356s #1327732 Wed Sep 25 2019 11:40 PM
Boltergeist
Bleed many of them but I always put a piece of material between the brake lining and the tool.
Pictures in my Photobucket
52 Chevy Panel
Achipmunk #1328531 Wed Oct 02 2019 03:56 PM
Surprised I could walk in to autozone and still get the correct MC. Had just
replaced 2 slave cylinders and MightyVac did the trick.
Clutch and brakes have more 'feel' than ever.
1960 C20
rc356s #1328800 Fri Oct 04 2019 10:39 PM
Some one mentioned pressure bleeding, that works good until a cap or cover leaks, then you have paint remover on everything. I much prefer vacuum bleeding, I use one of those oil suction pumps that way you have lots of capacity for the exhausted fluid.
Ret, Machinist , Industrial Engine
Engine specialist
Page 2 of 2 1 2
Moderated by  Justhorsenround
