The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (dsword, Joe Alan, latroca52, 2 invisible), 98 guests, and 6 robots.
Forums60
Topics126,066
Posts1,018,872
Members45,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Gas Tank on 1948 GMC 3/4 ton
#1319689 Mon Jul 29 2019 03:13 PM
RyanC Offline OP
As it appears to be that there is no replacement for the gas tank on a 1948 GMC 3/4 ton. The tank mounts partially under the cab and under the bed as well. I'd like to know if there is a modern replacement that will work in it's place. I was wondering if maybe one of the tanks off of a newer square body would fit nicely into place of if there is something else that is equivalent. I'd prefer minimal fabrication, although I know I will have to make some custom tank straps, but I would like it to mount in the same location, and be able to put the filler in a similar location as original as well. I believe the filler went through the filler piece between the bed and the running board on these. I figured since this was fuel delivery for the engine this would fit into the engine category, and I couldn't find anything on the subject in the search.
Re: Gas Tank on 1948 GMC 3/4 ton
RyanC #1319739 Tue Jul 30 2019 12:44 AM
ASU Offline
RyanC,
I have a flatbed on my 48 Chevy 3/4 ton, but had the same problem. I put a U-4 tank from Tanksinc.com in mine. the filler neck comes right over the frame rail.
Jon
RyanC #1319752 Tue Jul 30 2019 01:34 AM
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
RyanC #1319809 Tue Jul 30 2019 01:47 PM
That's where the fill neck should be on a 48. Picture of factory set up.
[img]https://i.postimg.cc/FYBtNvJK/gas-tank-013.jpg[/img]
Evan
RyanC #1319981 Wed Jul 31 2019 09:37 PM
RyanC Offline OP
The above photo is of the 1/2 ton version, the 3/4 ton does a similar thing but mounts more in the center of that spot since most 3/4 tons were 7 foot beds. The 1/2 ton gas tank mounts more towards the axle from what I have found in diagrams, but I couldn't find a diagram of a 3/4 ton. But that tank does mount about 1/2 under the cab, 1/2 under the bed.
RyanC #1327963 Fri Sep 27 2019 09:47 PM
RyanC Offline OP
Does anyone have any factory manuals or books that show what the gas tank and mounting would have looked like in a 48 GMC 3/4 ton? I was looking at a universal tank and wanted to compare the 2. I do not have a tank so I have nothing to go by.
RyanC #1327965 Fri Sep 27 2019 10:14 PM
Factory Assembly Manual Section 8, Sheet 1.01
Note that this is dated 1953. I'm assuming the '48 3/4 ton would be the same.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
RyanC #1327967 Fri Sep 27 2019 10:29 PM
RyanC Offline OP
That's exactly what the hangers look like, does it say anything about dimensions of the tank? That picture is very helpful, thank you.
RyanC #1327969 Fri Sep 27 2019 10:33 PM
That's all there is. No tank dimensions. You might be able to guesstimate the tank size by measuring the brackets. The Vehicle Information packet on the GM Heritage website might have tank capacity, which might help you get closer on dimensions.
RyanC #1328563 Wed Oct 02 2019 10:06 PM
RyanC Offline OP
Pictured above is a 48 Chev. 3/4 ton, I see the straps above, but how is that tank held in place? Isn't there a lot of frame bracing that is in that area as well? If there is room for that tank there could it be mounted from below? The other spot I am now looking at is the area where the spare tire would go. Either spot, I may need a little instruction on parts I'll need to fabricate to hold in the tank in place. At this point a factory tank will not be possible as they are just not out there.
Page 1 of 2 1 2
Moderated by  Woogeroo
