The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 registered members (KEVINSKI, HevyHauler, Gmetzger, 53 green 1- ton, 1 invisible), 357 guests, and 3 spiders.
Forums48
Topics117,072
Posts935,381
Members42,773
Most Online1,027
Dec 27th, 2019
Image Posting Policy
Free Engine, Trans and Rear 36 Chevy 1.5t #1323482 Sun Aug 25 2019 09:17 PM
JTRobb Offline OP
Free, just making space and i have no need for it.Enclosed drive shaft . Engine turns over but never tried to fire it. Engine and trans are sitting on a pallet. The rear is still under the frame but can be liberated very easily. Tire and wheels go with the rear, looks like there may be 2 that are new-ish.
[img]https://photos.app.goo.gl/A8fNtfRXXQaX5TMPA[/img]
[img]https://photos.app.goo.gl/Z2qksvD1wY66z29p7[/img]
[img]https://photos.app.goo.gl/F6JzWZkh2M2AXj3t6[/img]
[img]https://photos.app.goo.gl/Hi23JHFoiLCXB8sM6[/img]
36 High Cab 1.5ton
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1324804 Wed Sep 04 2019 03:48 AM
Y
yar Offline
Hello JT.
I have a '36 Chevy pickup that I've owned since 1965. I wonder if you'd be willing to part with the carburetor and air cleaner off that '36? Do you know if the carburetor has a tag on it identifying it?
Thank you JT. My email is raywaldbaum@gmail.com
Ray W
Ray
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1325122 Fri Sep 06 2019 04:07 PM
JTRobb Offline OP
I would like to get rid of the whole engine if possible. I will pull the carb and air cleaner and send it your way if it ends up headed to the scrap yard. Not sure if it has any tags, it is all wrapped up in plastic right now since it is sitting outside. I figure I have a couple weeks before my better half says something about my "junk" laying around and i'm forced to make a trip to the metal yard.
Jason
36 High Cab 1.5ton
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1325760 Wed Sep 11 2019 02:45 PM
Y
yar Offline
"I would like to get rid of the whole engine if possible. I will pull the carb and air cleaner and send it your way if it ends up headed to the scrap yard. Not sure if it has any tags, it is all wrapped up in plastic right now since it is sitting outside."
I understand. Please keep me in mind if nobody takes the complete engine off your hands.
"I figure I have a couple weeks before my better half says something about my "junk" laying around and i'm forced to make a trip to the metal yard."
I understand that also. My better 1/2 doesn't mind my "junk" collection either as long as she can't see it. If I set something small and clean down on the kitchen counter I find it moved to my shop the next morning.
By the way Jason, does that '36 high cab have a fan shroud? I looked for one for my '36 high cab PU for decades before finally getting lucky. It must have been a really rare option. I could send you a photo of it installed if you like. It's an odd 2-piece design but it does seem to work well. I found out about it from a service bulletin from 1936.
Ray W
Ray
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1325813 Wed Sep 11 2019 10:09 PM
JTRobb Offline OP
No fan shroud, just a fan and a radiator.
Jason
36 High Cab 1.5ton
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1327104 Sat Sep 21 2019 06:14 PM
Mike B Offline
Where are you located in Maryland?
Mike B smile
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1327157 Sat Sep 21 2019 11:47 PM
JTRobb Offline OP
I'm in Severn Md, 21144
Jason Robb
36 High Cab 1.5ton
Re: Free Engine, Trans and Rear 36 Chevy 1.5t [Re: JTRobb] #1327177 Sun Sep 22 2019 02:00 AM
Mike B Offline
I sent you a PM...
Mike B smile
Moderated by  Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
