The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Goach2, delky, dands, Texas Hussy, 1 invisible), 230 guests, and 3 robots.
Forums50
Topics120,033
Posts961,337
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
'56 6400 Brake upgrade
#1326640 Wed Sep 18 2019 10:48 AM
RmJr Offline OP
I need some help with my power brake system.
From the looks of it I need to replace most of the parts. I would like to upgrade to a modern master cylinder, with front and rear independent circuits.
I have searched Stovebolt and a couple other forums for a bolt in power brake system for Drum/Drum. I am sure someone out there has made this
upgrade, maybe even knows the part numbers used.
Has anyone had any luck sourcing an under cab master cylinder that works with the 6 wheel cylinder, 2 ton trucks?
Thanks in advance
Re: '56 6400 Brake upgrade
RmJr #1326664 Wed Sep 18 2019 01:45 PM
3B Offline
Hy RmJr, welcome, I have never seen a conversion kit from single system master to dual circuit master advertised for your size of truck. You have two basic choices a vacuum boosted system or a hydraulically boosted system, the hydraulically boosted system would require the installation of a power steering pump. I recommend using a dual master cylinder which has the same size bore as your original system, certainly not any smaller on the bore. You will probably have to piece together you own kit, just make sure everyone is aware these parts are for a drum/drum system. Good luck and don't be afraid to come back and ask more questions.
RmJr #1326668 Wed Sep 18 2019 02:49 PM
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1089476/1.html
This guy has installed a dual master/booster on his 2 ton. I think it was part of a front disc brake kit put together by 'RDomeck' so the master would be a drum/disc.
I tried to get one of them to cough up part numbers with no luck. Seems as though when it comes to making money with a kit part numbers are not something that is shared !?!
RmJr #1326669 Wed Sep 18 2019 02:50 PM
RmJr #1326703 Wed Sep 18 2019 07:03 PM
I seem to recall there is a late '80's Corvette drum/drum MC that could be used with any booster.
Ed
EdPruss #1326714 Wed Sep 18 2019 09:10 PM
Big Bolt Forum Moderator
Ed
Maybe for a 1/2 ton but not for a 2 ton, it would not have a big enough bore to push that much fluid.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
RmJr #1326719 Wed Sep 18 2019 09:44 PM
Noonan, If you knew the amount of time I have invested in making this kit work for these big old trucks you might understand that I am not making very much money on these kits. I have had a couple of guys run my master bracket with the modern dual circuit vacuum boosted master with success. I have not personally driven a drum brake truck with that set up, but As I understand, it works well.
On the kits, I am about a week away from having 5 kits put together for sale.
Randy Domeck
Indianapolis Fabrications
rdomeck@me.com
Indianapolis, In. 46254
317-258-0039
RmJr #1326728 Wed Sep 18 2019 10:29 PM
7
Vette's have been disc/disc since '63, unless that m/c was an aftermarket special setup.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
RDomeck #1326733 Wed Sep 18 2019 11:10 PM
RmJr Offline OP
Hi RDomeck,
I understand the work/time that you must have spent on this.
I PMed you earlier, I think we should talk.
Does anyone know the MC volume required to push 6 wheel cylinders?
78buckshot #1326734 Wed Sep 18 2019 11:12 PM
'63 Vettes were drum/drum. A friend has one that he's converting to disc.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Page 1 of 2 1 2
Moderated by  69Cuda, Grigg
