Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
12 members (Gdads51, baldeagle, frogfarmer, azcornman, 55shaker, Hotrod Lincoln, 2 invisible), 109 guests, and 3 robots.
The Zone
Forums65
Topics123,444
Posts999,547
Members47,279
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
Athab3 #1325238 Sat Sep 07 2019 03:15 PM
It is possible to remove the cab with the steering mast on the truck. As you lift the cab, you will need to gradually roll the chassis forward at the same time.
I would not try to do that unless you have a way to lift the cab straight up without it wobbling all over the place.
Athab3 #1325247 Sat Sep 07 2019 06:00 PM
Athab3 Offline OP
Thanks 52 Carl.I will have a chain block hanging from the rafters Then I will lift and move the chassis forward. Athab3
Have 55 GMC 9300 short box step side .Needs restoring but starts and drives ,no brakes, also have 59 GMC 9380 with very good cab for parts.have been doing MGA's all mjy life so this is new to me
Athab3 #1325274 Sat Sep 07 2019 10:18 PM
Athab3 Offline OP
garage is getting full Athab3
Athab3 #1325276 Sat Sep 07 2019 10:24 PM
Athab3 Offline OP
had to put comealong to lift front bit.Athab3
Athab3 #1325279 Sat Sep 07 2019 10:45 PM
Nice job!
Athab3 #1325291 Sun Sep 08 2019 12:13 AM
Athab3 Offline OP
Thanks Carl
Athab3 #1325914 Thu Sep 12 2019 05:30 PM
Athab3 Offline OP
removed engine from frame,built a temp stand to hold the engine and tranns.Gonna clean up the frame and paint before anything goes back on.Putting the 59 cab on and am seriously looking at using all the 59 front body ,fenders hood etc as the 55 is quite wonky.Will put the 55 box on and it will still be a short bed step side.
Athab3 #1325970 Fri Sep 13 2019 01:27 AM
the 58-9 front clip needs the frame to be a couple inches longer in front than the 5-7 frame - see here
Some TF series details [flickr.com] & TF heater pics [flickr.com]
Athab3 #1326004 Fri Sep 13 2019 11:13 AM
Athab3 Offline OP
Thanks Bill,So can I just weld an extension onto the front of my frame?Is the frame a bit longer just for front bumper attachment ? Athab3
Athab3 #1326109 Sat Sep 14 2019 01:30 AM
you might try that, but the difference is to suit the fenders and lower valance, which are longer, and the bumper has to fit correctly against that
Page 3 of 4 1 2 3 4
